Sbc very low oil pressure. Use thicker oil? - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 01-30-2013, 01:31 PM
bigdog7373's Avatar
Of course it's fast
Alright so I put 4qts 10w40 and 1qt 20w50, then my zinc additive which was surprizingly thick.
Cold idle neutral: 50psi, in gear 45psi
Hot idle neutral 10psi, in gear 6psi
Crusing at 50mph 23-26psi.
Not too bad. Obviously there is something wrong but at least I can drive it without worry now.
I'm thinking in the near future I will pull the engine and trans and sell them. Ive wanted to do an ls swap for a while plus I have a 4speed muncie that I'm dying to put in.
  #32 (permalink)
Old 01-31-2013, 05:10 AM
Richiehd's Avatar
JS-70
Why are you mixing oil weights? You live in Florida, you have a motor that probably has a little extra clearance in the bearings. Use a 20-50W Brad Penn RACE oil if you need the ZDDP. or Valvoline VR1.
  #33 (permalink)
Old 01-31-2013, 06:17 AM
bigdog7373's Avatar
Of course it's fast
Im pretty sure 5qts of 20w50 is going to be wayyy to thick. That's what we use for hydraulic fliud in our commercial mowers and the stuff is very thick.
  #34 (permalink)
Old 01-31-2013, 08:40 AM
Richiehd's Avatar
JS-70
Whatever.....read my last post!
  #35 (permalink)
Old 01-31-2013, 08:54 AM
How fast is fast enough?
I agree, no need to mix a magical concoction, but I'd go with 5W40 Mobil 1 unless you have an aggressive flat tappet cam. Also, think about changing your pump if you didn't when you rebuilt the engine, the pumps can wear a lot depending on the oil/filter you used in the engines prior service life.
  #36 (permalink)
Old 01-31-2013, 08:59 AM
lg1969's Avatar
Google "Tunnel Ram 406"
Before you start taking it apart try to fine another distributor and replace it.
Low oil pressure on SBC lg1969 Engine 30 05-30-2013 05:00 PM
Low oil pressure sbc 350 Lightspeed Engine 2 10-16-2011 01:25 PM
sbc low oil pressure 1967chevelle454 Engine 5 02-27-2009 06:02 PM
SBC HVP oil pump, low pressure tnsmith10 Engine 14 01-12-2009 05:28 PM
305 sbc with low oil pressure??? Help 91olds305 Engine 17 10-14-2002 06:57 PM
