10W40 will make a difference, hell just throwing in 1qt of 60w into what is currently in there will probably bring it up in about 30 seconds. Since its just rebuilt y9ou may be running large clearances and need a thicker oil, just go thick enough to get good idle pressure though (10psi) and leave it at that, too thick of oil can cause other problems too, especially on a street car that can see short trips where the oil doesn't get hot enough.
pressure
pressure is good but flow is MORE better.. (thats gooder english)
ck the filter for sure. i'd stick with the 10/30. have u ck'd it with a good gage at the dizzy port area ?? there are others on here of more knowledge then me.. |
20 psi at cruise is too low. 0 is also too low. chances are it wont last long before
![]() I would tear it down Dog. Something aint right, and you risk damaging some parts pretty seriously if not taken care of. A newly built motor should be resting at 40 ish at Idle when warm.
Fact is stranger than Fiction |
I thought a rebuilt sbc goes by the 10psi per 1000rpm rule.
I can't tear it down either, Im living in a rental house in a community that hates my car. No joke they yell at me for it being too loud and "unsightly". I'm 100% sure they wont be happy if I rip the engine out in my driveway. I'm going to exhaust all my options before I do anything like that. I'll try the heavier oil and new filter first and see how it goes. 10w40 will be enough? Hopefully that will get it up to an acceptable pressure. If not then Im not sure what I'll do with it. I've been wanting to drop an ls in there for a while now. |
Lots of places like that in florida , so I understand.
10 lbs per 1000 is a general rule. All of the 350 SBCs I have ever built have carried 40-45 PSI , fully warm on 10w30 at Idle. Sounds like You have a clearance problem somewhere. JMHO
20w40 in the summer and I have great oil pressure. 50000 miles later I am still running the same oil and have the same oil pressure.
Thanks. I was gonna try 10w40 with some w60 mixed in and a zinc additive for the flat tappet. |
If I had to take a guess, I'd say someone did not change the cam bearings OR installed them turned wrong (it's easy to do, been there myself), and I also had a guy bring an engine by that was a fresh rebuild with less than 1,000 miles NO oil pressure. The builder (who was supposed to know what he was doing,) did not use any assembly lube. Needless to say the bearings were all junk. But I am completely guessing. I have had good luck with "Hi-tach" and Lucas products for quieting down noises and increasing pressures a bit. I run one or the other in all my high mileage engines, but just my input on it. Either way you most likely have an internal problem and will eventually have to pull the engine, however the thicker oil or additive will buy you sometime. Again ALL of this is JMHO, Best of luck with it
Kelly |
Many of people rebuilt engines but don't do them correct to me building is if the factory would have done with all there specs not just replacing the rings and head work one needs to do all the bearings.
Try Castrol High Mileage oil oh im not saying you didn't do it correct im thinking you had someone do the work for you. Good luck my friend. Many moons ago a friend of mine rebuilt a 455 HD engine well he had so much blow by he had a water hose atteched to valve cover going under the car that was sad since he had all HD parts he just didn't put it together correct. |
Its an stp filter. I run them on all my cars. I don't know how long its been on there though, definitely gonna change it.
I'm not going to doubt that there are large bearing clearances, but the block checked out ok and the cam bearing looked faily new so I left them alone. No blowby or anything. It runs great and no noises. Could the pickup be clogged? Maybe from debris during breakin? |
That is a possiblity, not sure break in would have caused enough to clog it, but something may have. And for the record I wasn't saying you built the engine wrong just giving ideas of what may be the cause. After I read my post it did not read the way I intended. Sorry if I came across wrong. Kelly |
| Low oil pressure sbc 350 | Lightspeed | Engine | 2 | 10-16-2011 01:25 PM |
| Low oil pressure on SBC | lg1969 | Engine | 4 | 08-07-2010 01:45 PM |
| sbc low oil pressure | 1967chevelle454 | Engine | 5 | 02-27-2009 06:02 PM |
| SBC HVP oil pump, low pressure | tnsmith10 | Engine | 14 | 01-12-2009 05:28 PM |
| 305 sbc with low oil pressure??? Help | 91olds305 | Engine | 17 | 10-14-2002 06:57 PM |
