Sbc vibration - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2013, 12:31 PM
dgmalibu10's Avatar
Sbc vibration
Hi everyone I have a sbc 388 stroker with a th350 transmission and a 28-3200 b&m hole shot converter, I'm getting a bad sqeeking noise and vibration under my car. The faster I go the louder it gets, I'm not sure if the fly wheel is cracked or the converter is out of balance, if you let it idle and look under the car at the converter looks straight as a arrow .when you drive the car it feels like the cars going to fall apart .before I start ripping this thing apart any suggestions would be appreciated . Thank you
Old 06-13-2013, 03:06 PM
RWENUTS's Avatar
Do you have the right flex plate?
Is your stroker internally or more likely externally balanced?
Old 06-13-2013, 04:23 PM
Some stroker kits are external -one end , internal the other .
dave
Old 06-13-2013, 08:17 PM
dgmalibu10's Avatar
It is externally balanced, this issue just happen this year when I took the car out for the first time. Thanks for the replys
Old 06-13-2013, 08:32 PM
dgmalibu10's Avatar
Could it be something in the trans , the trans was rebuilt 2 years age but only has under 1000 miles on it.
Old 06-13-2013, 09:14 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
If it only does it going down the road, check the u-joints in the driveshaft. If one is bad it can make it out of balance by letting the u-joint work to one side. Another indication of a bad u-joint is squeaking like you described.
Old 06-14-2013, 09:13 AM
dgmalibu10's Avatar
It's makes the noise in park to, when you really give it gas it sounds like something's banging by the flex plate
Old 06-14-2013, 02:48 PM
ericnova72's Avatar
More for Less Racer
Check for loose torque converter to flexplate bolts, and loose flexplate to crank bolts.
Old 06-14-2013, 05:08 PM
vncruiser's Avatar
Gearhead
If you are using a 400 crank you must use the 400 balancer and flex plate. Loose convertor or flexplate bolts usually will give you a knocking sound. I would still check the torque on those.
RPM-related vibration on 350 SBC SUX 2BU Engine 10 10-01-2009 11:09 AM
Vibration at 2000 RPM in SBC. "HELP" 53 Studebaker Engine 19 10-06-2007 07:14 AM
406 sbc vibration johnsquicks10 Engine 12 04-24-2007 03:29 PM
SBC Vibration damper install question dirtydave Engine 6 07-24-2004 09:30 AM
sbc vibration,runs like a turd USA1 Engine 8 05-02-2003 06:50 PM
