SBC Vibration damper install question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-23-2004, 02:02 PM
dirtydave's Avatar
I've gotten my crank vibration damper installed on my 383 chev but I don't know exactly how far to go. I've heard that you should install it until you have resistance but I've had some resistance putting it on from the beginning. I can't see if it's through the seal yet and I don't want to push it against the timing gear.
I was wondering if anyone out there has a measurement for proper fit from the front of the crank snout to the front of the damper. Right now I'm looking at 1" on mine. Or if anyone has any other tips as to how far to go it would be greatly appreciated.
thanks!
Dave
Old 07-23-2004, 03:21 PM
DoubleVision's Avatar
Hate to be the one to tell you this, but the balancer slides against the timing gear, that`s it`s stopper.
Old 07-23-2004, 03:39 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
Put it all the way in, as far as it will go.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 07-23-2004, 07:34 PM
dirtydave's Avatar
Ok. I cranked the damper on until the whole rotating assembly started to turn. I don't have an installer tool; because of past problems I've had to drill and tap the crank threads to 1/2". So I'm using a 1/2" bolt and washer. Should I stop here or is there a better way to make an install tool that will pull the damper on further. I'm afraid that my bolt/washer method will leave me with a broken bolt in the crank snout.
Old 07-23-2004, 08:45 PM
troy-curt's Avatar
Set your water pump and crank pully in place and see how close you are.
Troy
Old 07-23-2004, 10:33 PM
MI2600's Avatar
Member# 3287
I just went through this with my balancer. There should be an inch between the front of the crank snout and the front edge of the balancer when the balancer is seated. That should put your balancer against the crank gear.
Old 07-24-2004, 09:30 AM
dirtydave's Avatar
Ok I've got the inch! Thank You!!! I actually found an installer tool that had the 1/2" threads and I broke the tool. Looks like the damper is all the way on. I'm just glad I didn't mess up the crank threads.
Well according to troy-curt "If you don't make mistakes, you're not doing anything." So it looks like I'm definitely doing something.
Thanks again everyone!
