Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC with vortec heads and thumpr cam timing/carb questions
Old 01-12-2013, 10:34 PM
Greg T's Avatar
Greg T Greg T is offline
www.krusinklassics.net
No, initial is with no vac. If it's bucking against the starter at 16* you have a problem. Either you're not at 16* or you have an electrical problem. Verify TDC on the damper by using a piston stop to be sure the damper is good and the timing tab is correct.
