sbc vortec vs lt1 intake bolt pattern shared or different - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2013, 03:52 PM
firehawkslps's Avatar
Simply put do the late model truck L31/vortec and the gen II LT-1 share the same intake bolt pattern? THANKS for your help; for the right person this is a no brainer, but right now thats not me, the ans. is holding up progress I've looked & googled ectra nojoy.
Old 02-17-2013, 04:31 PM
They're not the same. Whether they share the same bolt pattern or not is irrelevant. The LT1/LT4 uses a reverse-flow cooling setup that is totally different from the normal Gen I sbc cooling.
Matt
ETA: Or what Fbird88 said.
Old 02-17-2013, 10:36 PM
Originally Posted by F-BIRD'88 View Post
No they are not the same. The water passages in the head/intake manfold are different too.
So is the respective height of the intake port. Port alignment is not the same.
heads and intakes are not swappable between the GEN I motors and Gen II LT-1 LT4 motors.
A L-31 vortec head needs a vortec intake manifold. There are plenty available so no good reason to consider adapting other stuff.
All the "L-31 Vortec" engines are Gen I
thank you for your time everything you said is true and correct. I will for once do the smart thing and wait for time and cash to come together. After all it's only a good deal if it works and last. I run my 91 firbird in NASA HPDE QUITE OFTEN AND THERES A GUY RUNNING A LATER COBRA R IS GIVING ME FITS ON THE LONG STRAIGHT HES ONLY 10MPH FASTER HE'S 160 TO MY 150.mUCH AS ILIKE THE TPI SETUP ON THE STREET IT'S KILLING ME AT THE TRACK MY CURRENT 350/5.7L IS 350HP AT THE CRANK THE COBRA R IS 380. TIME TO UP THE AUNTY WITH A TRIPLE PLAY HEADS, INTAKE & CAM. I DON'T USE IT AS MY DD AND HAVN'T IN COUPLE OF YEARS.tIME TO MAKE A BETTER TRACK TOY. GOODBY TPI.
ROGER THANKS
SBC Starter Bolt Pattern, Patterns? 63ChevyII Engine 13 09-21-2012 08:43 PM
Question on SBC mini starter bolt pattern eric32 Engine 2 11-10-2009 07:43 PM
SBC flexplate bolt pattern lizardking7750 Transmission - Rearend 3 10-02-2009 04:51 AM
cooling a Toyota SBC and changing bolt pattern crownver General Rodding Tech 11 04-27-2009 01:26 PM
Lt1 intake for vortec heads? Newt408 Engine 1 12-06-2003 10:33 PM
