Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC Water Pumps
Thread: SBC Water Pumps
  #17 (permalink)
Old 12-28-2012, 07:25 PM
lakeroadster's Avatar
lakeroadster lakeroadster is offline
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
Originally Posted by Chevyshome View Post
one fella suggested that I should consider an electric fan setup..........that way I dont a shroud at all........!
Chevy
A good electric fan set-up still has a shoud. The only way to utilize all the surface of a radiator is to use a shroud, be it an electric fan or a fan driven via the engine. The shroud pulls air across the entire radiator.
If you simply mount electric fans right onto the radiator, with no shroud, only the area of the radiator adjacent to the fan will benefit from the cooling effect of the fans.
The Following User Says Thank You to lakeroadster For This Useful Post:
Chevyshome (12-29-2012)
