Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC Water Pumps
Thread: SBC Water Pumps
  #22 (permalink)
Old 01-04-2013, 08:16 AM
Chevyshome Chevyshome is offline
that sounds kewl enough alright..........but how will it work and or connect, to a 19 " clutch fan assembly......and just for the record.......I have a new rad core......and it only heats up over 180 degrees when the motor has been idling for a certain period of time ( the fan is not drawing completely through the rad itself in this case ).....and once again my fan is right now......approximately 5 1/2 " from the rad ......and why would an Allstar Spacer be any different than the 2 " Derale spacer that I was considering using...... also the only universal fan shroud I can find is 13 " in height.......therefore only covering a portion of the rad that the 19" fan draws through the rad..... thanks very much for your comments......I do appreciate it..........
Chevy
