SBC Water Pumps - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-28-2012, 02:18 PM
one fella suggested that I should consider an electric fan setup..........that way I dont a shroud at all........!
Chevy
  #17 (permalink)
Old 12-28-2012, 07:25 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Chevy
A good electric fan set-up still has a shoud. The only way to utilize all the surface of a radiator is to use a shroud, be it an electric fan or a fan driven via the engine. The shroud pulls air across the entire radiator.
If you simply mount electric fans right onto the radiator, with no shroud, only the area of the radiator adjacent to the fan will benefit from the cooling effect of the fans.
The Following User Says Thank You to lakeroadster For This Useful Post:
Chevyshome (12-29-2012)
  #18 (permalink)
Old 12-29-2012, 08:31 PM
yes.......I am gonna go with a Universal Shroud.......which is 5 1/2 inches thick......along with a 19 in. clutch fan..........and hopefully all should be well.........!
Chevy
  #19 (permalink)
Old 01-03-2013, 08:32 PM
........I went through a bunch of my old spare parts in a box I have and........I came across a 2 " aluminum spacer with a 5/8 pilot........I am thinking that this will take care of the situation and bring the fan to approximately 2 1/2 " away from the rad.........
Chevy
  #20 (permalink)
Old 01-03-2013, 10:04 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
In the first post you mention "hopefully alleviate a potential cooling problem". I wouldn't arbitrarily do anything until I knew for sure there was a need.
  #21 (permalink)
Old 01-04-2013, 04:18 AM
Last journal entry: 50 Ply wagon
Go to Jegs and check out the Allstarr fan spacers. I recently got one for my car. They attach to the pump separately with countersunk allen head bolts . That allows you to attach the fan or remove it without taking off the spacer.
  #22 (permalink)
Old 01-04-2013, 07:16 AM
that sounds kewl enough alright..........but how will it work and or connect, to a 19 " clutch fan assembly......and just for the record.......I have a new rad core......and it only heats up over 180 degrees when the motor has been idling for a certain period of time ( the fan is not drawing completely through the rad itself in this case ).....and once again my fan is right now......approximately 5 1/2 " from the rad ......and why would an Allstar Spacer be any different than the 2 " Derale spacer that I was considering using...... also the only universal fan shroud I can find is 13 " in height.......therefore only covering a portion of the rad that the 19" fan draws through the rad..... thanks very much for your comments......I do appreciate it..........
Chevy
  #23 (permalink)
Old 01-04-2013, 08:55 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
For one thing, using a 2" spacer and >2" long 1/4" bolts to mount the clutch/fan assembly will be stressing 1/4" fasteners a lot. Using a spacer that allows for shorter fasteners would be worth considering for that alone.
In the image below, you'd mount the spacer to the w/p hub w/one set of short fasteners, then mount the clutch/fan to the spacer using another set of fasteners. There will still be more stress on the w/p bearings, but all in all it's a better set up than a spacer using just four long 1/4" bolts.
  #24 (permalink)
Old 01-04-2013, 10:39 AM
You would be better off getting rid of the clutch fan and just getting a good pitched blade fan. The clutch fan adds alot more weight and the newer pitched blade fans have stainless blade with a steel hub and pull much more air at lower speeds and even more at highway speeds plus reduced weight on the pump hub.
  #25 (permalink)
Old 01-04-2013, 01:21 PM
TomJ's Avatar
fan
How about a flex fan with a spacer?
  #26 (permalink)
Old 01-04-2013, 03:57 PM
yes you have a point there........I was hoping not to have a problem with the bearing in the pump at all but.....I guess that is a chance I will have to take unfortunately......
Chevy
  #27 (permalink)
Old 01-04-2013, 10:04 PM
johnnyg's Avatar
hold my beer and watch this!
A flex fan takes away power. When the blades break watch out they will destroy everything in their path, waterpump, rad, hood, etc..
Anyone familiar with remote water pumps sbc ? Berg Engine 1 12-11-2009 10:18 AM
4.3 V6 water pumps 40chevcpe Engine 3 10-23-2007 06:53 PM
Water Pumps JJ350 Engine 3 02-21-2007 02:28 PM
water pumps cardaddyo Engine 8 10-17-2006 10:45 PM
SBC water pumps Eric64 Engine 13 04-13-2005 08:12 PM
