-   -   SBC water pumps (http://www.hotrodders.com/forum/sbc-water-pumps-61245.html)
Eric64 04-12-2005 08:11 PM
SBC water pumps
I would like some info on the difference between what I've read as to a long and short water pump,mines approx.7" in length is that considered a long or short and what applications use either one.I guess what I'm asking are they interchangeable? And if mine is 7" long how long is the other one? The block is a 92 350. Thanks for any help. Eric
MI2600 04-12-2005 09:30 PM
Chevy used the "short" pump until the late '60s. You probably have the long pump, but what do you mean by 7" long? Is that the height sitting on the work bench, i.e. from the water ports to the tip of the front shaft?
Also, if you have a serpentine belt system, you may have a reverse pump.
Eric64 04-12-2005 11:32 PM
Yes the height as you described it is about 7" I just see in descriptions some listed as short or long and was wondering about the lengths and compatibility,You mentioned reverse flow how would you check that out? it supposedly is a truck block 92. Thanks
bracketeer 04-13-2005 04:26 AM
water pumps
I know Corvettes used the short water pump up until 1982. Maybe they still do. Put the water pump up against the block. If it almost touches the timing chain cover. It's a short pump. If you can get your fingers between the pump and cover. It's a long pump.
Neophyte 04-13-2005 04:36 AM
What does the pump's belt pulley look like. Is it a V pulley or a flat pulley? A V pulley will be normal flow and a flat pulley will be reverse flow. A flat pulley has a serpentine belt running over it but with the belt's back side causing the pump to turn anti-clockwise against the clockwise rotation of the engine.
poncho62 04-13-2005 05:35 AM
The short pumps had the alternator on the drivers side head, whereas the long had it on t6he passenger side head.
The 92 trucks I have seen have had the serpentine belts, so probably a reverse flow, which is a long pump.
Long and short pumps do not interchange, due to the pulley setups.....They will bolt on the block however.
MI2600 04-13-2005 07:51 AM
I believe Corvettes had their own peculiar size, between the long and the short.
johnsongrass1 04-13-2005 11:54 AM
Nope. Corvette used a 3/4 front bearing. All others use the 5/8 bearing.
bracketeer 04-13-2005 03:00 PM
very true
I forgot that. They also have a larger center pin for the fan. I bought an adapter to convert from clutch fan to a PermaCool and I had to drill out the center to make it fit.
Eric64 04-13-2005 03:26 PM
I appreciate all the info, Probably a real stupid question but does the block care about pump rotation water flow? I don't have any idea what type of belt setup this block had in the beginning I got a bare block.Later I aquired a serpentine bracket setup mostly complete with a 100 amp alternator so I was leaning towards using that setup but I don't want to trash the engine I just finished assembling. If a v-belt setup would would be easier and would make the system more compact I'll use that what I'm trying to do is make the front of the engine as short as possible. So If I'm reading some of these post correctly a serpentine belt uses reverse flow pumps and v-belts use standard rotation as for short and long either will work with a v-belt but the serpentine needs the reverse flow. Thanks any more info appreciated.
MI2600 04-13-2005 03:46 PM
The block doesn't care.
steve t 04-13-2005 06:01 PM
fan
will your new fan turn the right way for cooling if revere flow, just wondering
poncho62 04-13-2005 06:02 PM
Requires a different fan also. The blades are reverse pitch...............
66Caprice 04-13-2005 09:12 PM
Not all serpentine systems use reverse water pumps. If there is an A/C compresser on one side and an alternator on the other, then it is probably a reverse flow pump, but if there is only an alternator and a P/S pump, it could be a normal flow water pump. It all depends on the design.
