SBC water pumps - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2005, 07:11 PM
SBC water pumps
I would like some info on the difference between what I've read as to a long and short water pump,mines approx.7" in length is that considered a long or short and what applications use either one.I guess what I'm asking are they interchangeable? And if mine is 7" long how long is the other one? The block is a 92 350. Thanks for any help. Eric
Old 04-12-2005, 08:30 PM
MI2600's Avatar
Member# 3287
Chevy used the "short" pump until the late '60s. You probably have the long pump, but what do you mean by 7" long? Is that the height sitting on the work bench, i.e. from the water ports to the tip of the front shaft?
Also, if you have a serpentine belt system, you may have a reverse pump.
Old 04-12-2005, 10:32 PM
Yes the height as you described it is about 7" I just see in descriptions some listed as short or long and was wondering about the lengths and compatibility,You mentioned reverse flow how would you check that out? it supposedly is a truck block 92. Thanks
Old 04-13-2005, 03:26 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
water pumps
I know Corvettes used the short water pump up until 1982. Maybe they still do. Put the water pump up against the block. If it almost touches the timing chain cover. It's a short pump. If you can get your fingers between the pump and cover. It's a long pump.
Old 04-13-2005, 03:36 AM
Neophyte's Avatar
I'm not superstitious
Last journal entry: Release catch for trunk lid pt.5
What does the pump's belt pulley look like. Is it a V pulley or a flat pulley? A V pulley will be normal flow and a flat pulley will be reverse flow. A flat pulley has a serpentine belt running over it but with the belt's back side causing the pump to turn anti-clockwise against the clockwise rotation of the engine.
Old 04-13-2005, 04:35 AM
poncho62's Avatar
Wiki Edits: 5
The short pumps had the alternator on the drivers side head, whereas the long had it on t6he passenger side head.
The 92 trucks I have seen have had the serpentine belts, so probably a reverse flow, which is a long pump.
Long and short pumps do not interchange, due to the pulley setups.....They will bolt on the block however.
Old 04-13-2005, 06:51 AM
MI2600's Avatar
Member# 3287
I believe Corvettes had their own peculiar size, between the long and the short.
Old 04-13-2005, 10:54 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Nope. Corvette used a 3/4 front bearing. All others use the 5/8 bearing.
Old 04-13-2005, 02:00 PM
bracketeer's Avatar
489 Lemans
very true
I forgot that. They also have a larger center pin for the fan. I bought an adapter to convert from clutch fan to a PermaCool and I had to drill out the center to make it fit.
Old 04-13-2005, 02:26 PM
I appreciate all the info, Probably a real stupid question but does the block care about pump rotation water flow? I don't have any idea what type of belt setup this block had in the beginning I got a bare block.Later I aquired a serpentine bracket setup mostly complete with a 100 amp alternator so I was leaning towards using that setup but I don't want to trash the engine I just finished assembling. If a v-belt setup would would be easier and would make the system more compact I'll use that what I'm trying to do is make the front of the engine as short as possible. So If I'm reading some of these post correctly a serpentine belt uses reverse flow pumps and v-belts use standard rotation as for short and long either will work with a v-belt but the serpentine needs the reverse flow. Thanks any more info appreciated.
Old 04-13-2005, 02:46 PM
MI2600's Avatar
Member# 3287
The block doesn't care.
Old 04-13-2005, 05:01 PM
steve t's Avatar
ex biker, now hotrodder
fan
will your new fan turn the right way for cooling if revere flow, just wondering
Old 04-13-2005, 05:02 PM
poncho62's Avatar
Wiki Edits: 5
Requires a different fan also. The blades are reverse pitch...............
Old 04-13-2005, 08:12 PM
66Caprice's Avatar
Move It On Over!
Not all serpentine systems use reverse water pumps. If there is an A/C compresser on one side and an alternator on the other, then it is probably a reverse flow pump, but if there is only an alternator and a P/S pump, it could be a normal flow water pump. It all depends on the design.
Diameter of SBC short water pump inlet ken47 Engine 1 11-25-2004 08:41 AM
motor plates sbc / water pump captainflyte Engine 2 11-03-2004 04:03 PM
Which waterpump? Eagle1 Engine 5 08-06-2004 06:38 PM
SBC short water pump vs long water pump and other questions Jag Daddy Engine 9 04-02-2004 09:29 AM
electric water pumps??? classic_chevy_guy Engine 3 10-24-2003 10:09 PM
