SBC, what carb?
What would b the best size carb to use for a sbc 350 with a comp cam kit duration 280 , 480 lift, and new valves and springs to match the cam, and a wienad team g manifold
Is that all that has been done to the engine no internal work / head work?
What heads are on it ? Cole
Stock heads 194 intake valves , msd street fire distributor, long tube headers, no internal work besides the cam, lifters and 1.5 roller rockers
Automatic with a stock stall and stock posi rear (I believe 355 gears )
Also has long tube headers cherry bomb vortex mufflers msd street fire HEI distributor
You need a 600 vacuum secondary. The automatic and 355 gear, stock 9:1 compression, Using the 280H cam it's a Holley #1850 carb.
Thanks for the advice , what is the benifit in this situation of vacuum secondaries instead of mechanical
With vacuum secondary it will less of a chance of bogging when hit the gas pedal.
Mech. secondary carb will have Lean bogging because of the gears you are using and the cam you have. It's even worst you are using a stock converter. Gas mileage will suffer with DP carbs. They are for all out racing. If you had a 4 speed tranny or a loose converter and 390, 410 gears, then 650DP will work very nice. Last edited by lg1969; 01-27-2012 at 03:52 PM. |
| Best carb spacer style Edelbrock carb | truckboy61 | Engine | 2 | 07-24-2011 09:18 AM |
| holley carb backfires threw carb | talleyho | Engine | 61 | 05-25-2011 10:03 AM |
| Will adding a 1 inch carb spacer affect carb tune? | eric32 | Engine | 29 | 02-09-2010 12:13 AM |
| Quadrajet Carb rebuild....parts interchange with another junk carb? | Warrant | Engine | 2 | 07-31-2006 10:44 PM |
| Any problems spraying carb cleaner in my carb while its on the motor? | batman09 | Engine | 11 | 11-29-2005 07:49 AM |
