There should be a location between the center two exhaust ports-
I tried that port on the head--fans would never shut off--my thought was that the switch is sensing the head temp and not the coolant temp-- If you have to use the adaptor that came with the switch>>>the sensor probe does not protrude into the coolant flow. If you have another location on the intake maifold--(I would put it there) Bryan |
I am pretty sure that the tapped hole behind the carb is for vacuum.
Power brakes, Tranny modulators, Vacuum Accys. etc If you have no sensor plugs in the heads between the exhaust ports, and only 1 hole in the front of the intake (that is not used by the heater) You may be able to use a thermostat housing with sensor holes in them. I am not sure how this would work----but you give it a try (if you don't want to use the head route) Bryan |
| SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine | Oldsmolac911 | Hotrodders' Lounge | 50 | 01-12-2011 10:00 PM |
| Whats the correct temperature my 350 should be running at? | batman09 | Engine | 101 | 10-23-2005 12:29 PM |
| Anyone know the path of the coolant in an SBC? | CHEV66JB | Engine | 0 | 05-12-2003 12:21 PM |
| SBC coolant flow question. | M&M CUSTOM | Engine | 3 | 05-09-2003 05:28 PM |
| SBC coolant spew | Harlequin | Engine | 6 | 07-23-2002 10:58 AM |
