Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sbc wont move freely after rebuild rebuild.
Old 12-10-2012, 12:12 PM
38Sedan 38Sedan is offline
Last journal entry: Body
Originally Posted by lmsport View Post
Each rod and rod cap assembly is unique once it is machined. Randomly moving the caps around and having the engine run is impossible. The rods were probably marked at one time.
Do you see any markings on the rods or the caps?
This is also true for the main bearing caps on the block. They too are usually marked and install in a particular direction also.
This is correct, trying to randomly move things to get it to turn is not the way to go. You need to measure, measure, measure rods and bearings.
