sbc wont power brake - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2012, 09:16 PM
hey guys i have s10 with a 355 steel crank eagle rods speedpro pistons 292 comp cam 501 lift double hump heads edelbrock 600 carb and edelbrock intake. the engine runs great from about 2000 rpms to 6500 but for some reason it wont power brake any ideas?
Old 04-04-2012, 09:26 PM
Greg T's Avatar
www.krusinklassics.net
Big cam, tight converter and high rear end ratio? Retarded timing? Lean carb?
Old 04-04-2012, 09:50 PM
idk about the coverter its got a decent size cam and 373 gears my initial timing is 19 degrees and total timing is 34 degrees and my carb is a 600 edelbrock so theres not much tuning i can do if it is lean any suggestions?
Old 04-04-2012, 10:01 PM
DoubleVision's Avatar
You don't have enough carb for one thing, but that wouldn't stop it from power braking. What intake are you using? Performer? Torker?
Get on dirt and do a brake test by getting up to 15 mph then slam on the brakes, if the rears lock up before the fronts do the rear brakes are adjusted too tight. If the converter is stock then the engine doesn't have enough low end torque with the given cam to power brake. What size tires are on the rear?
Old 04-04-2012, 10:21 PM
my87Z's Avatar
Veteran/Firefighter-Paramedic
I was thinking the torque converter, if it's to low of a stall speed then that answers your question. That cam is 244 @.050 and should be used with about a 3500 stall.
Old 04-04-2012, 10:44 PM
its got 315 tires on the back and the guy i got it from said there was a 2200 stall in it how can i tell? he also said that it had 3.73 but it seems more 4.11s or 4.33s cause when im at 65mph im at 4000rpms
Old 04-04-2012, 11:24 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
How tall are 315 tires? Jack up the rear and rotate the tires one full turn counting drive shaft rotations to find your ratio.
Semper Fi
Old 04-05-2012, 06:42 AM
my87Z's Avatar
that 2200 stall would be the first thing i would replace, i would go with a 3200-3500. that cam has a lot of duration to it and dosen't make much power down low, it makes it's power from 3000 up
Old 04-05-2012, 07:24 AM
thanks for the advice everyone im gonna go with a bigger stall and a bigger holley carb that should really wake it up any.
Old 04-05-2012, 10:20 AM
1971BB427's Avatar
Yeah, I'd say you're way lower geared than 3.73's! I'm running 3.73 rear and I'm turning about 2800 at 65 mph. Sounds like your rear gears are at least 4.33 or even 4.56, unless those 315's are really low profile.
Old 04-05-2012, 10:54 AM
yea im guessing 4.33 and no the tires arnt low pros im thinkin about changing the gears to a 3.73 cause i can barely drive it on the street
power steering pump for sbc with MustangII power rac TheCiscoKid Suspension - Brakes - Steering 5 12-29-2012 05:39 PM
No power, wont rev stea Engine 12 04-24-2007 02:44 PM
Brake light/turn signal lights wont work together ChevyForever Electrical 1 10-04-2004 01:19 PM
Brake lights wont work!!! stroked76 Electrical 2 10-15-2003 05:06 PM
Brake Lights wont Light! 97 Mustang GT Electrical 4 07-01-2003 11:41 AM
