GM car? Headers? Sounds like the classic "starter heatsoak syndrome". What size cables are you using? Remote solenoid?
Mark |
I would suspect the small gauge starter wires are getting to hot along with the solenoid. Check out this thread and look at the link I provided.
starting Seems to be a lot of these issues here this week. Read through the MAD site as you will find a TON of info there. Mark |
Actually 4ga. wire is adequate. Those small lights don't take much power to light up. Turn the key to "run" or whatever you do to get the dash lights to come on and then turn the headlights on. If the lights go out or get very dim, your battery is bad or you have a bad connection. If they stay on, you have a wiring problem. You could take your battery and have it tested.
make shure your getting power from the ignition to the starter wire,s also make shure you have a good engine ground to your battery,, and engine to frame ground is good,, also make shure your alt is chargeing with the right voltage should be between 13 or 14 volt.s
| Has spark & turns but won't start (won't even fire) | loafing1 | Engine | 2 | 04-12-2011 07:50 PM |
| Starter won't start and fuel pump won't pump after engine reinstall | Porschev | Electrical | 26 | 02-16-2007 04:43 PM |
| Won't start | THE CON | Engine | 2 | 06-28-2006 04:56 AM |
| Won't Start | fasano89 | Engine | 4 | 11-28-2004 11:57 AM |
| change modular car will start shut off and won't start back up | Ramman | Engine | 1 | 11-26-2004 08:20 PM |
