Sbc350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2008, 12:08 PM
Sbc350
Was Wondering If Anyone Could Help Id Engine, Block # 3970010(back) The Front Shows T51519841 K02 27 Tkf, I Myself Think It's 350 (69-79) Others Say 327 Any Suggestions
Old 03-31-2008, 02:05 PM
Mustangsaly's Avatar
look at www.mortec.com
3970010....302.....69....4...Z-28 Camaro
3970010....327.....69....2...Trucks and industrial
3970010....350...69-80...2 or 4
Old 03-31-2008, 02:07 PM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
You will have to pop open the oil pan and check the crank, then research the number on Mortec. Most likely it is a 350 though.
Old 03-31-2008, 02:42 PM
a 2 bolt main means it could of been a factory 327 or 350 engine block. a 327 crank in that block makes it a 327. 350 crank in that block rather its a 2 or 4 bolt main makes it a 350.
Old 04-01-2008, 08:47 AM
XNTRCI-T's Avatar
AKA Lee in KC
The code K02 27 TKF means...
K = St. Catherines, Ontario engine plant
02 27 = February 27th date of manufacture
TKF = 1975 350 out of a C-10 or 1500 chassis (pick-up, van or bus)
Info courtesy of NastyZ28.com.
Old 04-01-2008, 02:22 PM
should be a good builder 350
I grew up looking for builder 350s in pick ups, vans, school buss, C50 & C60 trucks. but most of the school buss's and C50 & C60 trucks had 4 bolt mains and factory gm steel cranks.
Front Engine Mount for 350 Chev Enigma10 Engine 9 03-24-2012 09:18 PM
'89 4.3L Cylinder Size Compared to SBC350 size (and gear drives) boneyard Buick Engine 10 04-10-2007 09:04 PM
sbc(350) timing mark problems jw4413nv Engine 6 08-29-2006 03:29 PM
good cam for a daily driven sbc350 66truck4spd Engine 2 11-22-2003 05:03 AM
sbc350 that eats cam lobes eblyon Engine 20 06-15-2002 11:49 AM
