sbc350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2012, 07:22 PM
sbc350
im rebuilding a sbc 350 replaced all the bearings,put a .485 lift cam in also lifters and valve springs for that lift.put everything back in order aligned the crank and cam like supposed to and installed the dist.. well it backed fired so i was 180 out so i aligned the crank to top dead center and relocated the dist and gas is coming up out of the carb... any suggestions? it will not satrt at all just crank,thats it
Old 03-04-2012, 10:19 AM
techinspector1's Avatar
Wiki Edits: 326
Follow this tutorial and you'll be ok....
http://www.crankshaftcoalition.com/w...stment_SBC/BBC
Good sbc350 buy? BmoreChevy55 Engine 4 08-18-2011 06:49 AM
Building a mpg sbc350 bigals77 Engine 8 05-01-2011 01:00 PM
Sbc350 SBC355 Engine 5 04-01-2008 01:22 PM
s10 transmission/sbc350 53belair Transmission - Rearend 1 01-22-2007 01:00 AM
sbc350 that eats cam lobes eblyon Engine 20 06-15-2002 10:49 AM
