Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sbc350 that eats cam lobes
Old 06-07-2002, 05:02 AM
HQ Pete HQ Pete is offline
New Member
Post
need a little more info like type of heads ,cam, valve lift,valve springs,roller or stamped rockers?....i figure you no about the all important cam break-in procedure(1500-2000rpm for the first 15 min and heaps of prelube).You may be right with your theory,also check for coil bind in the spring depending on the lift you have and rocker ratio it maybe on the limit.are your guide plates lined up ok ?give us that little more info and we'll go from there .
