Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sbc350 that eats cam lobes
Old 06-07-2002, 11:42 AM
slomotion's Avatar
slomotion slomotion is offline
Post
Did you install new lifters? An old set of lifters that were running on another cam will pick up a "finger print" that has tiny little scratches that you can't even see that will act like a file on a new cam lobe. It may be coincedence that the cam went south at the same time you installed the heads. That's my "swag" (sophisticated wild a** guess) Good luck!
