sbc350 shaky starts then surges and stalls? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2011, 09:06 AM
Asking about this starting and running problem I have w/mild 350 sbc. I've replaced the spark plugs, they were carbed up bad. Cleaned the fuel filter, bit of crap there. Replaced the fuel pump, oem mechanical , pumps good. I can start the engine ,but then it only runs for a bit and stalls. Plugs look wet. Checked the dist. cap, rotor and coil and all good. I don't use this pick up very much and I do use fuel stabilizer each winter for storage, put bit of new gas in. Is the base timing 10 deg.advance too much for what might be gas too old anyway?. What does old gas look like anyway? Which direction do I turn the dist. to retard it if necessary? Any suggestions are very welcome!
Old 04-23-2011, 09:58 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Ten degrees isn't too much timing for a mild build, do you have a screen filter in your carb inlet that may be clogged? Try your timing at around 14 and see what it does. You're setting it with vac advance disconnected and plugged, yes?
Old 04-23-2011, 10:09 AM
sqzbox's Avatar
My pipes are my music
What kind of distributor do you have? Need to check for vacuum leak/leaks.
Old 04-23-2011, 10:12 AM
T-bucket23's Avatar
Wiki Edits: 26
If this has carburetor you may have a choke that is not opening properly or a pull off that is not working.
Chet
Old 04-24-2011, 08:18 AM
New guy here again , most recent checks are...
Thanks for your engine starting problem tips. I cleaned the in line screen filter and there wasa little dirt in it. The edelbrock 600cfm square bore choke is in good working order and set to carb manual specs.
Yesterday I checked the spark and its orange and maybe small. Shouldn't this HEI spark w/ aftermarker MSD coil be blue and fat?
The fuel delivery is very good. The hotwire to the distributor is 12.43 volts w/
ignition switch on.
My '87 camaro z28 surges and stalls? papabear88 Engine 4 02-12-2009 02:47 PM
Sbc350 SBC355 Engine 5 04-01-2008 01:22 PM
starts then stalls markzepp820 Engine 38 01-28-2007 07:04 PM
Shaky oil pressure? Destructo Engine 2 09-28-2003 08:38 AM
shaky brakes pachotrod Suspension - Brakes - Steering 6 05-05-2002 06:07 PM
