Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sbf 306 running lean???
Old 03-16-2013, 04:36 PM
Hookedup12 Hookedup12 is offline
They can fix it. They are extremely good with what they do to old mustangs I've seen over 12 of the mustangs they've worked on at some of the car shows in nc, they specialize in older mustangs. They just gave me the option to try and fix what I have or go for a carb larger over the whole map not just jet and power valve that's all. They are going to Tune this carb as is. And if I want to move up ill try it with a 670 or 650 an record hp number changes. If it is worse ill drop back to 570 but if they make this one work there ain't no need to fix what ain't broke. "Custom" means it was specifically ground hydraulic flat tappet for my combo, I don't have the cam card in front of me so I can't remember right off. Other than the flat spot it runs like a raped ape.
