Two words. Hydraulic Roller Cam.
Ok, three words. The 91 will be running a hydraulic roller cam which will do 2 things for you 1. You don't have to worry about cam lobe/lifter failure w/ the newer oils like you would with the flat tappet cam in the 289. 2. You can run a cam w/ a more aggressive profile (faster opening and closing) and gain more power without losing streetability. If it were me, I'd go w/ the 302 just for that alone. Matt |
It's all not a bolt on. You may run into some problems depending on which timing cover you have, some early front covers have differences in the water openings from block to cover and will leak..water pump inlet on a 65 is on a different side as well. If you want to use the 5.0 front cover, along with your front sump pan and oil pump, get ready to figure out how to put a dipstick in it, as the dipsticks in the 5.0 are in the side of the block. (dual sump pan needs the dipstick in the rear)
I'd be inclined to find and run the dual sump pan and proper front cover. Also your accessory drives may wind up being a pain, you must run the 91 balancer, there is a significant difference in the balance weights from 65 to 91. The 91 balancer is set up for serpentine belts, and you will need to adapt a pulley to make it run v belts. I am not sure but IIRC Street & Performance and Ford motorsport has some stuff that will help with that. I saw a conversion balancer in one of the mustang catalogs, with the correct weight for the 81 and up motor and the bolt pattern for the v belt pulley. They usually have dual timing marks, one for the left side pointer and one for the right side...so pay attention to TDC on the balancer when you mock up the motor.. Do not forget to get the proper flexplate /flywheel, as the imbalance factor is different from 81and up.... If you do run the 5.0 front cover, you need to use an electric fuel pump, or find a front cover from an 84 and earlier that will fit the block, those had carbs. Pay attention to the water pump as well, the later one is reverse rotation There are differences in intake gaskets as well, but if you are buying heads, you should be able to figure out which ones you'll need. Swapping parts on some Fords is more fun than a busload of fat chicks. It can be done, but it will take some work. Do a search for "5.0 in early mustang" and there should be alot better info than what I just gave you. I have an 84 5.0 in my rack that came out of a 67 mustang, when I get ambitious I'll climb up there and look at what's on it. Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example Last edited by powerrodsmike; 05-04-2009 at 08:14 PM. |
The '91 302 had forged pistons from the OM. They're a popular engine when a roller forged piston engine is wanted- like for nitrous or super- or turbocharging.
You might go ahead and pick up the engine and just put it away for when you DO need it. |
Mikey, that's what I was looking for! Thanks buddy. I know the block I have is a 65 because it states it on the engine gully on the casting and I know it's a 289. The timing cover and water pump appear to be from a 67 or later because the water pump outlet is on the drivers side, where the 65 and 66 were on the passenger side. I'm running a mechanical fuel pump on the timing cover which I know the 5.0 doesn't have (electric pump) and the dipstick goes into the timing cover on my engine versus the 5.0 to the rear of the engine. I was figuring I could use my oil pan and the entire front (timing cover, pump etc.) I thought the pickup tube could be replaced to work with my oil pan (front sump). I didn't think about the balancer which is a 28 oz. on mine or the flywheel. I assumed they would work. 289/ 302 are the same? I also didn't consider the serpentine belts or it the reverse flow on the water pump would make a difference after changin the complete front portion of the engine with mine. I'm running a V belt on mine which runs the crank, water pump and alternator (one belt). The 5.0 blocks looks identical to the 289 and I guess that's why I thought it would be a easy swap. Maybe, I'll just go with a early 351W motor if I can find one. I guess that would also have to be a prior 1988 or so engine as well? Or just keep my 289 and throw some aftermarket heads on it. Thanks for the great info guys.
The 289 and 5.0L blocks are not the same. The 5.0 is a lot weaker in the mains...
See this... http://sbftech.com/index.php/topic,15644.0.html Just over halfway down the page you can see how little material is actually used... |
Yes, they are weaker, but that guy was running 18psi of boost AND a 100hp shot of nitrous. That's with a cast crank and cast main caps. I think the split block may have been a result of the mains/crank giving up instead of the cause. I think the same block/caps/crank would live for a very long time in a more reasonable setup. That being said, if it were me, I'd swap to the 5.0. Not that the 289 is bad by any stretch, but I think the odds of having a cam failure from the 289 flat tappet is much higher than having crack issues with the newer block. But either way, it'll be a good setup. Matt |
If you have a 65 289 then it will be a five bolt bellhousing block and the 5.0 will be a six bolt block. If you want to change your tranny and only gain 13 ci then go with the 5.0. If it was me I wouldn't waste my time pulling a good running 289 to install that 5.0.
None of the 65 289 motors had 5 bolt bellhousings. There might have been some carryovers of C4 blocks into 65 cars, but if it has a C5 prefix it's a 6 bolt.
Check the casting numbers. http://raceabilene.com/kelly/hotrod/engine2.html Later, mikey.
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
This is not a difficult wsitch at all and I have done it a few times already with relative EAZE. The balancer and flexplate are a given. The only thing you will need to make sure is you use a flexpalte that allows you to go from late to early trans. The rest as far as I'm concerned is basically the same. You will need a front sump oil pan. The early timing covers will fit the 5.0 motor. I have never encountered a problem there. An early water pump will bolt right up.
Don't let people fool you, this is relatively an easy swap that's done almost daily. You can also run V-belt system with the roller.. Some things about this swap are just simply implied by design.. meaning you would not expect to be able to use the reverse rotation water pump. Your 289 pump will work and work well. Front sump pan (which you can use from your 289) Balancer (which should come with the motor) Flexplate $100 that allows you to go late to early Hook everything up, pick up extra cubes and a motor that will run circles around the 289. NOW, from a nostalgia standpoint.. I wrecked my brain about this.. mainly because the 289 is a dying breed. if you've got a good block (not bored past limits), I would probably put some heavy consideration into it. I debated this for months, but opted to go with the roller and glad I did. This things is a dream to drive and my gas needle hardly ever moves. I'm running a edelbrock performer with a holley carb. Got good throttle response, good torque, great gas mileage in these lighter cars. I kept my 289 and will never part with it, but rollers are the way to go. Makes the driving experience so much better. How many miles are on it. |
Another thought.. going to a 351w in these little stangs would be a complete nightmare IMO. This is why your buddy opted to build a 347.
351 in early mustang: Too heavy No room for working around Makes the car nose heavy Just a natural PITA I know guys that done it and they are not wild about it.. other than saying they have a 351. |
I'm sure I have a 65 289 Block and heads going by the C5 engine coding. The 66 289's came with the smog port heads (CA edition) those are on my 66 Mustang (not one of Fords better ideas!) and was the first year for smog pumps. The 289 is a 6 bolt and actually has a 68 C4 Transmission butted up to the block. I believe the 260's and the early 289 like 63 to 64 did have a 5 bolt block but that was changed in 65. I got a lot info on this switch and some great info. Thanks everyone. The 289 block was rebuilt before and I have no clue who did it or if it was crate type purchase, etc. The previous owner didn't even know that info. I've had the heads off and the engine is very clean and no ridges or wear visible on the cylinders. I haven't checked if it was ever bored over, I'm assuming it was if it was rebuilt. I recently had the heads done, basic 3 angle valve job and had screw in studs machined in instead of the pressed in studs which came with the heads. When I replaced the cam in the 289, it actually starting pulling the studs out of the heads. And I'm running a mild cam with a 480 lift - 273 duration. The heads have less than 5,000 miles on them since they were done. It's by no means a dog and holds it own for a 289, but is no where near the performance of the 5.0 when it was running in the 91 Stang. I'm guessing I may be better off at this point in going with some aftermarket heads, with perhaps 1.6 roller rockers instead. I can always switch the heads to the 5.0. if I decide to go that way. I thought this would be an easy one day-er pull the engine and drop the other in, instant 100 horsepower project. I'm glad I asked before possibly getting in over my head on this one. I think the price, and knowing how fast the 5.0 was got me excited. Heck, I'm still excited, just not sure if it's worth going this route. I think if I'm going to go through all this trouble, I'll make it worth my while and stuff a 351W in the engine compartment. I've got the room. For now, the 289 runs!
Still thinkin? Ed |
| Difference in rotors on gen 3 Camaros | Cole32 | Suspension - Brakes - Steering | 5 | 01-30-2006 11:49 PM |
| Lincoln Welders - Is there a difference | robin58 | Garage - Tools | 6 | 01-25-2006 07:21 PM |
| Whats the difference | 5dogsisenuff | Body - Exterior | 9 | 09-18-2005 08:57 AM |
| color difference in 2 k primer | Rosewood | Body - Exterior | 4 | 05-28-2005 08:36 PM |
| what's the difference??? | ap0001 | Hotrodding Basics | 5 | 01-14-2005 08:47 AM |
