SBF motor the street - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2012, 02:35 AM
Hi all,
I'm putting together a new motor for my Mustang and would like some advice on the build. I've been offered the following parts:
Edelbrock E-Street heads 1.9/1.6 valves.
CompCams High Energy Cam Adv' Dur' 268/268 .456 lift, with matching lifters and
double roller timing chain set
Roller Rockers
Weiand Street Warrior 4v intake
Holley 600 v/s carb
Would these parts work together or should I be looking for a different set up ?
Old 01-25-2012, 05:39 AM
Irelands child's Avatar
Originally Posted by MustangBrit
Hi all,
Roller Rockers
Holley 600 v/s carb
Tell us more of what you have to begin with, engine wise and where you want to be when done.
I don't believe that is a particularly good combination. Without knowing that base engine nor its year, 289, 302, 5.0L, it is kind of difficult to make full recommendations. If it is a roller camshaft engine block, makes it different again.
These are fairly good pair of heads with decent valve size for a street driven car - but that camshaft will not be much help. One thing to consider - with stock or stock replacement type pistons, I would limit valve lift to ~.500+/- a few thou. with 1.6 ratio rockers.
Since you are probably speed shop limited in England, I would suggest that you stay with a "kit", and use an Edelbrock Performer intake and camshaft, the unknown brand roller rockers and an Edelbrock 1405 or 1406 600cfm carb to go with those heads. You can upgrade to the Performer RPM as well, but the baseline RPM range does move up and your rate of use of $10/gallon of premium gas does as well.
Again, tell us more as well as what kind of budget you are looking at.
Dave W
350 street rod motor kennyhammond Hotrodding Basics 10 12-16-2011 05:05 PM
Sbc street motor ETs NovaJoe1973 Hotrodding Basics 9 12-08-2011 05:23 PM
What is a street motor? Jsup Hotrodding Basics 4 11-09-2009 11:43 AM
ZZ4 cam for street motor??????'s mupton Engine 4 07-23-2009 10:23 PM
What do you think? street motor- rookie builder Hotrodding Basics 32 04-16-2009 08:09 AM
