Even if someone had done the exact same build, their answer wouldn't necessarily be valid for your motor. There are too many variables. Main bearing centerline of the crank to the rod bearing centerline could be a little different. Rods could be a little different length. Piston compression height could be a little different. Block deck height could be a little different. Position of the valve seats in the heads relative to the head mating surface could be a little different. Even using the same exact heads, the valves could be sunk in the seats further on one head than on the other one. The gaskets they used could be a little different. The rockers they used could have a little different ratio, etc., etc.
Each and every engine build stands alone. You must check the clearance on your particular motor.....yourself.
