Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBF Rod Bearing
Thread: SBF Rod Bearing
Old 08-18-2008, 08:04 AM
CNC BLOCKS NE CNC BLOCKS NE is offline
Originally Posted by Arrowhead
I pulled my 302 apart and am going to do a rering and bearing job on it. The connecting rod cap has round pin in the middle at the bottom of the cap and the bearing has a hole to fit over the pin. This is in additon to the locating tangs on the edge. Will standard replacement bearing have a hole for this pin, or is it something special? (Don't rmember seeing these on other motors I had apart.)
Thanks
It sounds like there alumimum rods and they need to be bearings that have the dowel holes in them which are special bearings.
