Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBF Rod Bearing
Thread: SBF Rod Bearing
Old 08-18-2008, 09:27 AM
gregb gregb is offline
Standard bearing for a SBF won't have that hole. You might be able to remove the dowel from the rod and then you wont need the hole, what is this engine in and what is it's intended use? If it is some endurance engine or max effort drag engine I could see the extra effort to dowel the rods, although I don't think that practice is as common as it was way back when, if it's just a street engine I don't see a need for them.
