SBF water pump rotation
Is this pump reverse rotation or forward?
Yes, that is reverse rotation. Cold water from the radiator comes in from in front of the impeller feeding into the center of the impeller. Impeller rotation is clockwise as looking at the photo you posted, the impeller is pushing the water out from under its center into each scroll to the pump outlet ports that feed into the block.
Ok, thanks.
Here is the problem. Customer brought in a 67 mustang with a 92 302. He wants to keep the serpentine but he's only spinning the water pump and an alternator. I think what I'll have to do is add an A/C delete pulley so I can route the belt to get enough contact on the water pump. Anyone done this? |
Either something like you suggested, or go to a set up like March uses for conversions in place of V-belts. Water pump pulley is grooved for the serp belt instead of smooth so it can be run in the same direction as V-belts, just like the V-belt routing. You can get just the single waterpump pulley from March, you don't need to get the whole kit from them. If you look you may find other sources for a serpentine grooved water pump pulley also.
| Water pump leak SBC help | sexypizzaman | Engine | 10 | 07-19-2008 03:08 PM |
| 65 Mustang (1975 302) overheating promblem. Water pump question | Robert08 | Engine | 4 | 06-22-2008 11:45 AM |
| 351W Water pump application question | RAW | Engine | 7 | 11-13-2006 04:24 PM |
| BB Chevy Coolant Leak @ Water Pump | leejoy | Engine | 3 | 07-04-2006 01:10 PM |
| water pump heater hose conenction.... | oldcarguy85 | Engine | 3 | 04-07-2002 09:34 AM |
