Scarf cut sealing rings 4T65E - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2010, 06:24 PM
Has anyone ever scarf cut the sealing rings on this transmission? And if so what were the results?
Old 11-03-2010, 08:34 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
If you are talking about scarf cutting a solid plastic type ring.... just cut the ring at an angle with 1/4 inch or longer scarf cut.
I stick a good sized socket in a vice and use that as a mandrel with a sharp x-zak-o knife ... cut it slowly , do not get your fingers. not that I have ever done that.... mayb
Watch the ring when slipping it into the bore of the drum, noit to cut or smash it
Old 11-03-2010, 09:00 PM
Thank you sir
"Basics of Basics" Sectioning a Body MARTINSR Body - Exterior 7 11-24-2008 01:04 PM
Chop and channeling. how to....? baugh353 Body - Exterior 15 02-07-2006 08:21 AM
Tip of the day #13 MARTINSR Body - Exterior 6 12-24-2005 04:09 PM
Question about removing roof 86caprirs Body - Exterior 3 03-27-2005 01:21 PM
