Scat 9000 crank VS stock 400 crank? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2005, 03:20 PM
New Member
I am getting ready to build a 383 stroker for boost, but am on a budget. I was wondering which crank would hold the most power. The Scat 9000 383 stroker crank says its good to 500hp and 7000 rpm's. How much can a stock 400 crank handle? Thanks in advance.
Tony Moore
Old 03-01-2005, 04:48 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
I would not recommend either one for a boosted engine, but I have seen alot of guys run stock cranks with good luck. The main deal is to keep RPM reasonable and use lightweight pistons and rods. That will make the crank live alot longer.
Chris
Old 03-01-2005, 04:49 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Ditto. HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 03-01-2005, 05:09 PM
Going boost and going budget usually doesn't work too well for too long. My choice, wth gun to head, I'd go with the Scat.
Old 03-03-2005, 10:22 AM
New Member
Chris
Hey Chris, what crank do you recommend?
Old 03-03-2005, 10:54 AM
TurboS10's Avatar
Wiki Edits: 2
4140 or 4340 Eagle or Scat at a minumum. Lunati or somthing of that caliber is nice, but will cost you.
Chris
4ma crank vs stock clevo crank carnell Engine 1 08-17-2003 05:56 AM
400 Hp Stock Engines-im Pissed! bullheimer General Rodding Tech 22 07-17-2003 03:09 PM
chevy 400 buildup 406chevelle Engine 15 06-08-2003 03:41 PM
Stock eliminator 78 monte Engine 5 01-02-2003 05:10 AM
how much will stock rods and crank take? nastynova Engine 7 12-30-2002 05:03 PM
