The "3400" could be the stroke, a "10" (or 10-10, 10-20, etc.) often indicated a turned down journal. If your engine has a 3.4" stroke (commonly used to make a 347 ci Ford) and you used a .010" under bearing, that would be a pretty good indication. ![]() More photos of a Scat cast nodular 3.4" stroke Ford crank from Skip White: |
BTW. I put that sump temp sender pic up for you. Al. Just adding this note from an email i just received from the tech dept. Scat Enterprises in California. I guess this answers the question of what the "F" is for. LOOKING AT THE PICTURE, YOU HAVE A 4340 FORGED CRANK. THANK YOU, BRIAN Last edited by 67Mustang Al.; 07-23-2012 at 07:38 PM. |
Got it, thanks. I've already uploaded it to the wiki, just need to find (or make) a home for it.
I sold one on e-bay a while back,and it looked identical to what you have except it didn't have the "F" stamping.And mine was a cast unit.
Big differance in big bucks though,as the cast unit is an import that Scat sells Paisano |
The way i drive the 67 , its never going to suffer a bottom end failure, touch wood. Now i can "big note" about the engine when someone asks.Al. P.s. Apart from the HV pump pushing too much oil for my needs, i thought the pressure was creeping up on the analog electic gauge . I noticed just beofre i drained the sump and took off the pan that the gauge was reading 20 psi with ignition on , wthout the engine. I swapped it out for a check with a mechanical gauge and found the true oil pressure to be 60 max and not 80. AFter cutting open the "chinese" sender i found the end wound loop had slipped on the insulator giving a false reading. Learn soomething evey day.
Al. LOOKING AT THE PICTURE, YOU HAVE A 4340 FORGED CRANK. THANK YOU, BRIAN |
Your lucky,cause your crankshaft is double the price of the cast.There is a site
called "survival motor sports .com" they do nothing but Ford FE's and all the parts are listed there from Scat rotating assemblies to complete motors.Their big block ford knowlege will blow your mind. Good luck, Paisano, |
![]() Al. Scat Ford Small Block 4340 Forged Crankshaft, 3.400 Stroke 5.400 Rod Length, 2.123 Rod Journal, $1,101.45 and $602.76 for the cast. |
| Forged or cast crank? | 31oldschool | Engine | 9 | 10-12-2009 03:42 PM |
| Scat Cast 9000 crank....? | PairOf69's | Engine | 9 | 09-14-2008 08:12 AM |
| is there a visual way to tell cast from forged crank? | MM in NM | Engine | 4 | 11-17-2005 08:03 PM |
| Anyone here ever used a SCAT 4130 forged crank? | badazz81z28 | Engine | 2 | 10-28-2004 07:49 PM |
| Scat forged or cast???? | 406chevelle | Engine | 13 | 06-20-2003 05:12 AM |
