Scat cranks? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2004, 09:16 PM
Scat cranks?
Im just posting to see what people think that have run these cranks... Any problems etc? what kind of RPM were you turning?
Old 05-09-2004, 09:18 PM
Having good luck so far, shift at 6800 has gone to 7500 on accident a few times. My machinists said that scat cranks overall are good cranks just some are harder to balance than others.
Old 05-09-2004, 09:26 PM
mstngjoe's Avatar
http://hotrodders.com/search.php?s=&...der=descending
Old 05-10-2004, 12:04 AM
Sandflea427SS's Avatar
Anything with a throttle
6,000-6500 RPM.....Great cranks....I've only used the 9000 series though.
Old 05-10-2004, 08:18 PM
lonewolf3197's Avatar
Chief Petty Officer, USN
Last journal entry: My Monte Carlo
I'm running one in my 94 Camaro. LT-1 Stroker and I consistantly shift at 7200 rpm and haven't broken it yet. Make sure you use a realy good assembly lube like royal purple when putting it together. I had to take mine back apart after 6000 miles due to low oil pressure turns out the cranke was scored. I had a friend tell me to use a better lube on the scat cranks when installing them and to baby em until they are good and broke in.
