Scat Rod Bolt Torque - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2004, 01:43 AM
Does anyone know what I should be torquing these rod bolts to:-
Chevy SB, Scat 4340 Forged I Beams with 3/8 12-point ARP 8740 cap screw bolts
Old 06-29-2004, 07:09 AM
Rogers Performance's Avatar
mike
Old 06-29-2004, 07:21 AM
King of my Man-cave.
With the moly lube, you're looking at aroung 65-70 ft lbs to get .006" stretch. USE A STRETCH GAUGE.
tom
Old 06-29-2004, 11:25 AM
tom
machine shop tom - does this imply that I should be putting moly on the main cap bolts then - currently it's engine oil only and 65/75 lbs
Mark
Old 06-29-2004, 03:07 PM
If you are using ARP bolts or studs, use their specs. If you are using stock bolts, use oil and torque to stock specs.
tom
