Scat Rods - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2009, 09:00 PM
Scat Rods
Anyone had any problems with parts house bearings fitting Scat Rods?
Old 04-16-2009, 04:51 AM
Last journal entry: PICTURE TEST
rods
Please explane in detail what your asking about.
What engine family, chevy, ford, honda, etc??
I beam or H beam??
What brand of bearings and part number???
Keith
Old 04-16-2009, 06:48 AM
scat rods
My bearings that fit fine on the cap but will not center on the rod. They are H-beam for Ford 5.0. The notch in the in the bearing won't allow the rod to fit the journal because it sticks out on one side. And like I said the cap is fine.
Old 04-16-2009, 07:27 AM
rods
what length are the rods??
What brand bearing and part number are you using??
any chance of you post a picture of it??
Keith
Old 04-16-2009, 07:37 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You might try a different bearing from another lot to see if the bearing was sent out wrong.
If a bearing from another lot fits the same way, the problem is likely w/the rod manufacturing/machining.
Old 04-16-2009, 09:58 AM
Are the bearings marked upper and lower???????
Old 04-16-2009, 10:53 AM
MrB MrB is offline
There are 2 bevels on the big end of the rod. The larger one goes to the outside, away from the other rod, to clear the radius on the crank. Noticed this on my SBC with SCAT rods. Not only is the bearing not centered, the small bevel won't clear the radius on the crank.. all bad..
Old 04-16-2009, 08:01 PM
scat rods
Thanks Guys,
Found out I had to have 351W bearings to fit the rods........Go Figure....
Scat / Pro Line connecting rods, sbc. Rad Ray Engine 3 12-12-2007 08:38 PM
scat crank ,pistons rods bill barnett Introduce Yourself 2 02-10-2006 06:49 PM
5.7 rods in 400 joefromcocomo Engine 9 02-05-2004 11:59 AM
new rods or old rods? Blob Engine 12 02-03-2004 04:35 PM
longest rods in std deck 454 bbc?? deuce_454 Engine 11 01-30-2004 10:06 AM
