Scatter sheild? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2003, 05:58 AM
Post Scatter sheild?
i have 77t/a with a 3-spd manual behind a 455. My freind told me people would start calling me stumpy if i didnt get a "scatter sheild" and the clutch happened to blow. Is this a real concern? Fragments of clutch cutting my legs off?
Old 02-13-2003, 07:32 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
IF you are revving high rpms and racing, yes it is a real danger. Don Garlits perfected the rear engine top fuel dragster after he blew off half of a foot in a clutch explosion.
Old 02-13-2003, 07:37 AM
Post
Thanks. Do you know where i would get one? Is it just a piece of metal that goes over the bellhousing? Would i have to remove the tranny to install it?
Old 02-13-2003, 07:58 AM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
Post
kevlar. for the weight concious. or you could weld plate metal ( i'd say 1/4 to 3/8") to your trans tunnel around the crucial area. I think jegs or summit carry ready to go scatter sheilds.
check <a href="http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=2158&prmenbr=361" target="_blank">this</a> out.
Old 02-13-2003, 08:44 AM
Post
yep ik thinkin a couple of bills for feet and legs is a worthwhile investment. thanks for the site
Old 02-15-2003, 09:27 PM
Thumbs up
As far as a Scattershield Lakewood makes a very good unit. You can order one from Jeg's or Summit and you also need to order a Mr. Gasket adjustable pivot ball to mount the clutch fork for proper operation, also use a steel flywheel for added protection like a Hays or Centerforce. If your going to be banging gears do it safely. I use the Hays flywheel and Lakewood Scattershield in my 71 GTO and have had no worries and no regrets. Used to replace stock flywheels about every year due to cracking from dragstrip abuse on a regular basis.
