scatter sheild
Hey guys. Should I be looking at going to a scatter sheild instead of my stock bell housing. It is mainly a street car that may see the track a few times a year. Motor is a SBC making aprox 450HP (estimated). I have a saginaw 4 speed(I'm sure it will blow up before the clutch let's go) with stock bell housing. It should hook pretty good as I have mickey thompson drag radials 295/55/15
Please let me know if we need more info |
If you have an aluminum bell housing,some race techs wont allow you to race. Its kind of like asking if you should buy leathers for a motor cycle that you only drive on hot days and its only 1,000 cc s
I think the bell housing is a cast steel. I'm not sure Vin but I think that's your way of saying "yes you need a scatter shield":)
I bought a scattershield for my car.I doubt I will drag race my car,and it didnt cost that much. If you have a cast bell housing they are decent and would likely stop a disc.Ive never seen a flywheel come unglued. I remember when I was a teen and reading about Don Garlits losing part of his foot. I also use an SFI approved balancer. I just dont see any reason to cut corners with safety equipment.
Like you said though,the saggy will likely break before anything else. Have fun at the track,,,, |
A friend of mine was over today giving me a hand and he was the one that brought it up. He has a new "tildon" (am I spelling that right?) Scatter sheild and throw out bearing (the kind that bolts to the inside of the scatter sheild) he will sell me for $300 which works out pretty good as have one of those cheesy floating thow out bearings made by Ram. It has already failed once and it has very little miles on it. I'm just waiting for it to go again.
He vin is a scatter shield just a skookum bellhousing or is it actually a sheild that goes over the exstisting bellhousing?
its a replacement bell housing made of steel.It has 2 parts,a big plate that goes against the back of the block.Some people leave that part out
JMO but I would go with the scatter shield. You already said it would give you a better throw out bearing set up and $300 is cheaper and more convenient than a prostetic leg :D. Plus you would probably stand to lose a few pounds if your housing is cast, but again thats just my opinion.
Here is the rule from the NHRA Rulebook, 2012. This rule applies to E.T. Handicap Racing, which is the type of class that 99% of the guys who drive in off the street will be in. This is bracket racing, so speed and E.T. are unimportant. Only thing that matters is cutting a good light and running on your dial-in. 11.50 and slower E.T. can use stock pieces, but you have to ask yourself, what are your feet and legs worth? I was standing in the starter box on the starting line at Firebird when an early Mustang fragged a stock, cast iron flywheel. It nearly cut the car in half. The flywheel busted into 3 pieces and the one that came through the cowl went several hundred feet in the air, then came down and landed just a few feet from the fuel trailer, which was in the pits, maybe 100 yards from the starting line.:eek::eek::eek: If I remember correctly, a small piece went through the side of the driver's shoe, but did not injure him.
CLUTCH, FLYWHEEL, FLYWHEEL SHIELD Flywheel and clutch meeting SFI Spec 1.1 or 1.2 (two-disc maximum) mandatory on any car running 11.49 (*7.35 in the 1/8 mile) or quicker. Flywheel shield meeting SFI Spec 6.1, 6.2, 6.3, or 9.1 mandatory on all cars running 11.49 (*7.35 in the 1/8 mile) or quicker. Cars with rotary engines running 11.49 (*7.35 in the 1/8 mile) or quicker must be equipped with a flywheel shield made of 1/4-inch-minimum-thickness steel plate surrounding the bellhousing 360 degrees. See General Regulations 2:3, 2:5, 2:6, 2:10. |
I hate tech inspecters that count all the bolts.There are 2 bolts that are quite difficult to get in because of firewall clearance.
rules are rules though.I have all of the bolts in and all of them are grade 12.The grade 12 bolts have a nice colour |
A piece of shrapnel flew across the track and nailed a 17 year old spectator in the chest/arm...... Timothy Daniel Ditt, age 17, with his fingers in his ears turned slightly to the left in anticipation of the final race towards the tracks end was suddenly hit on the left side of his chest and left arm that spun him violently around. Blood sprayed out of his left arm as it hung by only an inch of skin from his bicep. The shock of the sudden and massive blood loss from having his arm almost cut clean off had Tim screaming in horror. The crowd around him cleared away from him as the spraying blood covered everything. A man ran down from the top of the stands and laid Tim Ditt down. Moments later another man stuck his thumb into Tim's armpit to slow the blood loss and save his life. Tim looked up at the man trying to stop the arterial flow and went unconscious. Tim Ditt never saw Garlits' dragster explode, or the part that hit him. |
Clutch explosions..This is what happens..your choice to keep your feet or not..
Sam https://encrypted-tbn2.gstatic.com/i...Kzwdv9XHyuF8fg https://encrypted-tbn0.gstatic.com/i...iAqeywiyXBRXvg https://encrypted-tbn0.gstatic.com/i...RJiOqCEr2EDeFh |
tech,who was that guy in the black cowboy hat? was it smokey?
thanks for the correction BTW.I just remember that when I was 18 or 19 and I bought my first scattershield for my 67 Camaro.It had an aluminum bell housing |
| All times are GMT -6. The time now is 05:22 PM. |
