scatter shield - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2013, 11:07 PM
scatter shield
Hey guys. I'm in the market for a scatter shield. I'm looking at buying the one in the link below from a friend (new in box). Its not SFI approved but I won't be quick enough for that to matter. I just don't want to get injured (or killed) if I have a clutch failure. My question is will this Tilton bellhousing contain a clutch failure just as good as a lakewood,Mcleod,etc ??
Tilton Sonic Formed Steel Bellhousings 12003 - Mobile SummitRacing.com
Old 02-19-2013, 12:11 PM
Thishttp://www.aascomotorsports.com/tilton/sonic.pdf site says it
"Meets 1⁄4'' thick steel requirements of many racing series"
Old 02-22-2013, 02:22 PM
It's 1/4" thick, but the bottom part is designed for ground clearance, so likely you have to use a smaller flywheel/starter.
Old 02-22-2013, 06:55 PM
The ground clearance thing is good as the car sits pretty low. I have the small fly wheel and starter already so it should bolt right up.
Old 02-22-2013, 11:06 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
There is more details than just getting the bellhousing. You want a plate between the engine and the clutch to help protect the back of the engine too.
Without a mid plate with extra long dowel pins,you want in the case of a bellhousing failure,a cable to run under the engine to prevent the oil pan from dropping down on the steering linkage. If that where to happen,it takes a really bad day and turns it into a miscible day when you can't steer it. Grade 8 bolts only please.Really doesn't make much sense to have a bellhousing contain the explosion to have the bellhousing to block bolts shear off.Remember with a stickshift car and the shock loads your putting the drive train though,you'll only as good as the leakiest link.So the u-joints of the caliper of Lakewood's,to driveshaft loops,to a rear end that can take the shock load,to axles.
Now I know you didn't ask this question,but I think it is something you want to consider.You like anyone should be doing everything you can to get the car to hook.Stick shift cars are known for wheelstands.They might look cool,but unless your prepared for the track's largest wheelstand of the season,it will be the regret of the season for you.One thing I am speaking of is oil control and a trap door in the oil pan to prevent all the oil from rushing to the back of the oil pan. Of course a consideration for a front suspension that can survive a wheelstand without lost of control or damages.
I hope I gave you some help and food for thought.
Race or hot rod safe and in the end I hope you have the same fond memories I enjoy.
Old 02-23-2013, 11:05 PM
I'm thinking it might require a flywheel even smaller than 153T...
scatter sheild prostcelica Hotrodding Basics 49 12-28-2012 06:21 PM
Heat shield? 1953 Homer Engine 2 06-20-2008 04:32 PM
Scatter Shield & Blanket bonuts Transmission - Rearend 2 05-05-2005 03:24 AM
heat shield gawdzilla General Rodding Tech 2 06-16-2004 05:47 AM
Scatter sheild? joefromcocomo Transmission - Rearend 5 02-15-2003 09:27 PM
