Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Scatter Shield & Blanket
Old 05-04-2005, 10:42 PM
TurboS10's Avatar
TurboS10 TurboS10 is offline
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Scatter blanket is designed to cover the body of the transmission, and a bell housing or scatter shield is still needed for the event of a catostrophic flywheel failure. You need to remember the rules are to protect you. A flywheel or main shaft will take your leg(s) off before you know they are gone. Spend the money.....
Chris
