Scenes from my shop. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2004, 10:54 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Finally took some snapshots of my shop. It is a 1700sqft wood frame, stucco building that is finished on the outside the same as our house (CC&R requirement). I plumbed and wired it, installed the air system (3/4" PVC pipe) and dust collection system (4" plastic drain pipe w/ copper static ground wire inside). The first photo is the outside. To the right are two doors into the three car bays. One has an 8' door the other is a 10' door. Straight ahead is the paint booth with the air inlet filters visible.
The second photo is looking at the three car bays. The Pontiac and willys are in the first two and my king cab pickup project is in the far bay. You can see the pickup bed standing up to the right of the picture.
The next pictures shows my pride and joy - a hydraulic hoist in the middle car bay. Welding station/steel work bench is in front of the Willys.
Here are two shots of my wood shop section showing the dust collector a I scratch built, air compressor & band saws (I built the 12" one from a single sheet of plywood and 12" cooler pulleys. Works great!). Door on the left is to the commode and door on the right goes into the paint booth.
The finals shot is of the spray paint booth, just on the other side of the wall with the air compressor. See door into the wood shop back right. See the 3000cfm cooler blowing out with filter pads on the outside that vents the painting fumes. Plenty of light and a drain in the center of the floor so I can wet sand and wash down the shop prior to painting.
Old 02-17-2004, 01:30 AM
dinger's Avatar
That's a great looking shop, the willys looks mean on the lift. Ia this behind your house? How far is the truck from being a driver? Very nice, it looks like you put some thought into the layout. Dan
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 02-17-2004, 01:31 AM
diablos_50's Avatar
New Member
man, that is one sweet sweet shop. i am pretty jealous.
Old 02-17-2004, 02:13 AM
milo's Avatar
point on positive
Very Cool...is there beer in that frig?
Old 02-17-2004, 02:18 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Willys....how tall are your ceilings? I see where the Willys is on the hoist the rafters have been boxed around for clearance. BTW nice garage!!! I need some space like that.
Kevin
Old 02-17-2004, 05:56 AM
302 Z28's Avatar
OK Willys, the shop is very nice, but how in the world do you have time for hotrods, woodworking, and model cars?
Vince
Old 02-17-2004, 09:14 AM
Wiki Edits: 21
Dinger; got my powder coating done so can start going back up on the wheels, get the body on, paint etc. Should be on the road this fall, God willing. Yes, the shop is just behind the fence where you dropped off the front end parts. Roll out of bed and I am in the shop!
Milo; no, that fridge has my gas cans and welding rod!
Kevin; ceilings are 10' and yes, I did have to build that vault in the rafters to top out the hoist. Though this was a better solution than building a shop with 12' ceilings! Just hope no county building inspector stops by to chat! For that matter, they don't know about the hoist, water system, or wiring either!
302; since you asked, I also make a lot of commission stuff that eats into my important rodding time like a doll crib and high chair of cherry and mahogany with a couple dozen turned spindles for my grand daughter's 2 yr birthday this month and a curio cabinet for a raffle fund raiser for the Cancer Society next month. Built it from mahogany using a Wood Magazine plan.
Came out pretty nice if I do say so myself.
I am driven to get stuff done. The older you get, the more you realize you mortality and are driven to produce. I also have tried to eliminate sleep which is a HUGE waste of time. I have it down to abut 4 1/2hrs/night but can't seem to get below that.
Old 02-17-2004, 07:47 PM
302 Z28's Avatar
Is that your wife Willys?
Vince
Old 02-17-2004, 08:40 PM
Sandflea427SS's Avatar
Anything with a throttle
Good evening Mr. Willys...Great looking garage Mr. Willys....I can wet sand and paint and install parts and sweep the floor....When can I move in Mr. Willys.....I can scrounge food from whatever scraps are in the garage...old sandpaper.....pieces of wood.....congealed paint.....I would like to sleep in the corner out of the way....Four and a half hours...just like Mr. Willys!!!!
And 302....That is Mr. Willys daughter...the future Mrs. Flea....
SO WATCH IT!!!!
Old 02-17-2004, 09:53 PM
Pencilneck314's Avatar
Crap, hand me the grinder!
Last journal entry: Back on track
Man, oh man....
Thank God I don't have a shop that big. Cause if I did, I'd be divorced, paying child support for 2 kids.
Pencilneck314
Old 02-18-2004, 12:40 AM
Wiki Edits: 21
Naw, that's just the chick in the magazine article. I didn't get a good photo of my cabinet before I delivered it. My wife is MUCH better looking that that!
Old 02-18-2004, 12:53 AM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
anyone who has a commode in their shop rules.
once again, Willys is the man.
Old 02-18-2004, 02:25 AM
Kevin45's Avatar
Does a tree outside around the corner count also?
Kevin
Old 02-18-2004, 02:54 AM
Kevin
lol, nope! i got one o them trees myself.
Old 02-18-2004, 10:23 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
I dont need no stinking tree, I just step out the door. I thought that is what privacy fences are for....
Chris
