Schedule 40 pipe for trans crossmember? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-03-2006, 11:07 AM
Hi,
I've been reading the differences between DOM tube and plain-ol black water pipe all morning and I still can't figure out if a 1.25 inch "Home Depot" steel water pipe will work as a transmission crossmember. The wall thickness is like .150" and it is made of very heavy STEEL.
Reason: I would like to add support to/or completely replace my current (weaklink) crossmember which is bolted up to the original 4-cyl tabs on the sheetmetal frame. The tabs on the frame are about 10 inches forward of the trans mount and Im not too sure about the geometry of the whole set-up.
Any input would be appreciated.
Old 10-03-2006, 11:49 AM
I wouldn't go cheap here, DOM has a lot more carbon in the steel and therefore is not as easily bent. Also i see no reason square or rectangular tubing wouldn't be better. It shouldn't cost that much you only need 4-5 feet.
Pipe V.S. Tubing
Black pipe works, but is not a high stress rating. We use .095 wall seamless tubing for all of our race car chassis, and supports. Works quite nicely. Black pipe can do two things, Break and Bend. Neither of which is something you want to happen while going down the road. If you have some Circle Track car builders in your area, they probably have a short piece laying around that they would give you or sell at a very low price. Do not risk safety over expense.
Old 10-03-2006, 12:13 PM
thanks guys. I read that Schedule 40 pipe has an approximate yield strength of 30,000 psi. I though that was more that enough to hold my trans in place! I guess there's more to it than that.
It's not that Im cheap. I just dont want to look for a steel supplier. Every time I've bought rough steel I feel that I get ripped off. I guess I'll just look for a good supplier around here.
Old 10-03-2006, 02:28 PM
Is that 30,000 psi tensile, shear or compression?
The problem is if it bends, not breaks mind you, the fan hits the fan shroud, blades come off and go thru radiator, engine over heats, etc.......
saving a little money be using low grade steel on a cross-member can cost you 10-100 fold if it fails. I wouldn't do it, but then again, i'm not footing the bill either.
Old 10-03-2006, 02:45 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Well here is my thinking......galvanized pipe is to run water or air through..period. Black pipe is to run natural gas or LP gas through. Pipe is just that...Pipe. I do not consider it structural material. Go buy you some steel tubing square or round and build your cross member.
Old 10-03-2006, 02:56 PM
OMG if it broke....see... I have front motor mount plates that hook up to the water pump. If that trans crossmember broke the engine would drop down onto my steering linkage that would either break the linkage off and render my steering wheel useless or completely freeze it where it is. Then the transmission would likely go all the way down to the street and my driveshaft would be found somewhere in my cabin. LoL sound horrible huh. perfect timing for Halloween.
I just convinced myself to make it out of the strongest stuff I can find. I'm strengthening the one I have now. Adding more mounting locations and more steel. can't overbuild something like that. right?
===Thanks for the sound advice.===
Old 10-03-2006, 03:45 PM
Banned
personally I would have made it out of heavy water pipe because of the strength issues- now you are oging to have fabrication problem due to the fact taht it does not bend easily, but if you want a test of strength, take the biggest sledge hammer to a section of that pipe adn then to a spare cross member. I say sapre because while the pipe MAY get a small dent (more than likely not though) a usual factory crossmember will get torn up. The bad thing about the pip-e is that it will not yield as much before rupturing- basically you have no warning if it will fail.
Old 10-03-2006, 03:46 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
You should have a raer support on that engine if the front is mounted at the water pump. You need a mid mount. You don't need to find a big steel supplier to find small pcs of steel. There should be some kind of a fab shop around and they will sell you what they call drops for next to nothing.
Old 10-03-2006, 04:28 PM
I've been thinking about another engine mount. But my Vega has absolutely no room to fit standard motor mounts. As long as the trans is kept up- I don't see how the front mounts made from 1/4" plate can fail. Don't many very high horsepower setups have these type of mounts? They are the Hooker mounts that get bolted to the waterpump and the 4 holes on the lower front of the block.
The trans mount that comes with the set is garbage. It bolts the trans to a very thin part of the floor. Even my current setup is better than that. Plus it didn't give me the right driveshaft angle. So thats why I am where I am.
Old 10-04-2006, 06:08 AM
Tbucit's Avatar
Last journal entry: Kinda showing off
Ap's post
Just wanted to make a quick note about his post. The "hammer" test is NOT a recognized standard in the industry. Even if a piece of black pipe will not dent as much as a square or rectangular tubing it doesn't mean that it is stronger. Black pipe should never be used for ANY structural member on a street car (mounts, cross members, frames etc). I am all for scrounging to make the pieces I need but nobody wants to have a car that has the constant potenial to come apart at any time. A few dollars or some good scrounging will provide anything you would need.
BTW There is no need to use DOM (Drawn Over Mandrel) tubing (the most expensive) for this project. Seamless tubing would be excellent and a good heavy wall welded tubing is more than enough.
This time this is not an opinion but the facts LOL
One quick thing most of the front plate mount engines also have a plate at the bellhousing area to hold the end of the engine.
Randall
Old 10-04-2006, 06:35 AM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
If you run only a front motor plate and a trans mount, you are leaving a long length unsupported. This stresses the tranny bellhousing which may lead to separation from the engine at a most inopportune time. The mid plate solves this issue.
Old 10-04-2006, 06:37 AM
I have never used pipe but I don't think you would ever have a problem.
The thought of using it just doesn't seem like a good idea. For what little tubing you would need, I don't see much of a cost difference. That being said the black pipe would probably be stronger than the flimsey tubes in some of the crossmember kits you can buy. I agree with the above post. You should have a mid plate.
Bob
Old 10-04-2006, 05:15 PM
pipe
Go to a plumbing supply store and order some schedule 80 pipe. Dont go cheap!
Old 10-04-2006, 09:06 PM
Glennk's Avatar
pipe
Every time I read about using pipe for something on a car, on this site I read all these misconceptions about pipe. Pipe is just as strong as mild steel tube of the same approx. size. The only difference is the size and finnish..Pipe is rolled rough finnish . I would not be afraid to use pipe...as far as breaking, thats BS....Of course it doesn't look as nice but thats your decision...GlennK
Exhaust Diameter Formula ChevelleSS_LS6 Engine 11 04-27-2012 09:21 PM
air lines CARGUY Garage - Tools 96 11-16-2006 04:11 PM
Sanding "bondo" with 40 or 36 a No-No! MARTINSR Body - Exterior 44 05-15-2006 09:32 PM
Airlines Kevin45 Garage - Tools 22 03-04-2004 04:35 AM
Is 2 1/2 pipes big enough? Mustang_Killa66 Engine 7 02-12-2004 08:04 AM
