School me on gauges - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2011, 12:05 PM
dirty dixon's Avatar
School me on gauges
I have a 54 chevy 3100. The electrical system has been converted to 12Volt. I am wondering If I can use my original 6v gauges. There are two gauges: The speedo & the cluster of oil, temp, fuel, & amps
The speedo I going to assume I need something to step down the voltage going to it, hook up a cable and it should be proper. (Or am I dead wrong?)
The cluster, I would assume I need to reduce the voltage as well.
-how do I accommodate for a SB350 replacing the stock engine?
(that would affect the temp & oil)
-The gas tank will be a different volume, when I install a new on under the bed.
Any light on the topic would be helpful.
I have some experience with other forms of electrical work and can solder well. So If I can I would like to modify my original gauges.
Thanks.
Old 04-05-2011, 03:49 PM
EOD Guy's Avatar
If you have the funds check out Dakota Digital, They have factory looking ready made etc...
Old 04-05-2011, 04:52 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
The only electric going to your speedometer is for the lights, take your 6v bulb to the auto store & find one that's the same except it's 12v (about same candle power, single contact single filament. about same physical size bulb)
Aren't the oil pressure & water gages mechanical? As for the bulbs do as before.
The gas tank. The sending unit in the tank is an adjustable rheostat.
Rich
Old 04-05-2011, 05:02 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
It should be relatively easy to come up with a resistor to run the original electric gauges if you so desire. Maybe even a Ford or Chrysler pre-electronic ignition resistor would get your voltage where it needs to be. JMO ......Allan
Old 04-06-2011, 08:51 AM
I checked out Dakota, I'm just not into digital gauges. I really like the style of the original gauges. The repop's look good but, are a bit on the expensive side.
thanks for the info gents.
Old 04-06-2011, 09:24 AM
ogre's Avatar
the 'Duracell Project'
i believe rs3rd is correct in that you have mechanical gauges.
IMO you should bypass the amp gauge or convert it to a volt gauge.
if you add to the electrical system, i don't see a need to run all the load thru your dash.
i converted my 58 amp gauge to a volt gauge.
Old 04-06-2011, 01:57 PM
ogre,
thanks. do you have some pics of your truck posted up? that thing is sweet.
Old 04-06-2011, 03:35 PM
EOD Guy's Avatar
These look rather cool.... IMO
http://www.dakotadigital.com/index.c...rod/prd737.htm
Old 04-06-2011, 04:13 PM
Hi
That looks nice did you happen to check the price. That price part makes them unattractive.
Rich
Old 04-06-2011, 06:42 PM
ogre's Avatar
dirty
thanks, i have a bunch posted in the 55-59 truck thread,
but there are over 2100 posts in that thread
check out my photobucket album
also look in the mobile uploads, as i send a lot from my cell
don't worry, no naked ogre pictures in there...
the internet is not ready for that
Old 04-07-2011, 03:52 AM
EOD Guy's Avatar
They are kinda pricey but it is a very unique look
Old school motor in new school chevy or pontiac Tryin2MakeIt Engine 4 01-31-2009 08:26 AM
Old school meets new school lilchev80 Engine 4 05-06-2008 10:06 PM
Old School With New School Scheme, Good Idea? inkster Hotrodding Basics 3 06-12-2006 08:17 PM
Another school shooting, this time it was at my son's school.. RetroJoe Off-Topic 6 03-18-2006 09:47 PM
what auto school after high school camino_man Hotrodders' Lounge 2 04-28-2005 09:02 PM
