School me in high performance SBC's.
So here is the deal everyone. I am not new to building an engine,although I know very little about building a high performance one.
What I am leading up to is a lesson in what makes one head/rod/piston/cam better suited for an engine than another. For my build I want to have the most RELIABLE power I can make with my 327 I have read alot about different combo's of internals but never seen a description of why THAT combo. A few things I am curious about: why are longer rods beneficial to an engine. How to I choose "my" optimal camshaft. what is the necessary equation to find piston hight,and compression. What do the terms:static compression,squish,and dwell among others mean ? How to decide on heads,what does the size of the runners have to do with the performance of an engine ? |
Sorry......Thanx for the helpful,and kind reply. I was a little worried I would get frowned on for being a dumb@$$. Now for me to give you a little info on what I am working with: 1936' chevy 2-door sedan,camaro 5-speed trans,zoom aluminum flywheel,4:11 rear gear,unsure on tire size as I am just gunna have to see how big I can fit once the car is ready.I will be running a 65,000 volt dizzy,and will build long tube headers to fit the car once finished.
The car will be a cruiser for the most part,but it will see some 1/4 mile blasts(I'm all about acceleration). I am wondering if I should go 3.73's instead to maintain a little less RPM while cruisin' ? As far as heads go,I am unsure hence all the questions. I was looking at these heads in the 190cc version http://www.skipwhiteperformance.com/...?Item=3303-CYL They are available in either angle or straight plug design so i'm curious as to how much difference there is between the 2 For a real world app. ? |
stay way from these heads, they are made by ProComp and are very questionable, they have had major quality issues in the past and have the flow numbers of other aftermarket 170cc heads. if you do get them then buy them bare not assembled and have them checked out by a machinest, then have them assembled with the parts your machinest recomends, these heads are also in serious need for some port work to be done to them to make them perform anywhere near what most 190cc heads do. my advice is to just stay away from them.
here are some good heads but you will pay for them, but for anything decent you are going to pay for them. http://www.competitionproducts.com/A...tinfo/AFR0916/ http://www.competitionproducts.com/B...fo/BRO1021003/ http://www.competitionproducts.com/D...tinfo/D1864SA/ http://www.competitionproducts.com/R...fo/RHS12317K1/ even these would be a really goo fit if you dont plan on turing it up much past 6000rpm, and unless you plan on going with a solid cam or a hyd roller cam these are the heads that i would recomend the most http://www.competitionproducts.com/R...fo/RHS12410K1/ Tech1 is 100% correct about the angle plug heads, and all i have ever seen them do is burn up plug wires left and right. the 383 idea is right on the money if you have the loot, but if you build the 383 i would still stay away from the ProComp 190 or just about anything that says ProComp, why not just start with a set of heads that you know will preform well from a company that has not had near the amount of issues, and by-pass all that extra machine work. if you were to go with the 383 i would recomend the AFR 195's, DART iron eagle Platinum 200's or the RHS pro action 200's, maybe even the Pro-filer 195's Last edited by my87Z; 06-06-2010 at 09:13 PM. |
My 36' would be considered heavy ? I would not have thought that as it is a "skin" only car that came with wood. I am at the stage of building a body structure rite now. I am not arguing though,just surprised.
My choice of engine is because I have the engine,I like them because around here they are the "under dog" and considered a waist. They have been Compared to the 305. I would really like to stay away from a stroker,because it is such a "cookie cutter" engine. keep the info coming guys I really appreciate it ![]() What about this package ? http://sdparts.com/details/scoggin-d...ter/sd8060arpm What about Brodix heads ? do they offer anything that might fit the bill ? They are only 45 minutes from me. |
i have to disagree Tech1, i respect the whole idea. i dont think he is looking for crazy power. and although it is a small motor i like the 327. but i will say that this would not be the project i would be putting a 327 in. i would choose something very light weight, like a late 70's early 80's malibu, vega, monza, or maybe even an old datzun teamed with a 4-5sped and running the 327 up to say 7500rpm that would be a fun screamer. anyway i wouldn't consider the 327 a cookie cutter engine, but opinions are opinions. about the vortec kit from scoggin' dicky, that is a bit over priced at 1109.00 here look at these; http://www.summitracing.com/parts/SUM-151124/ 619.00 for the pair http://www.summitracing.com/parts/EDL-7116/ now you're at 806.95, and you could find head gaskets, intake gaskets, and bolts for less than another 300.00 |
To me selecting a combination begins with a bunch of questions about a project. What is reliable power for a bracket racer is different than reliable power for a daily driver.
How much is the car going to weigh ? Do you have any E.T. goals ? If you have an E.T. goal that will lead you to how much power you need to make and an rpm range based on the displacement of the engine used. This will help with choosing the proper sized heads, gearing etc. |
what do you guys think my car will weigh in at ? I really thought it would be considered a mid weight car. As far as how much hp/tq. ? I have no true goals.
I'm after a quick revving engine,that can take being daily driven. I'm after the " wow,a 327 you hardly see them anymore "....."damn thing runs pretty good to ! " kinda thing. Not a drag car,and I'm not out to beat the corvettes out there running around. And yea, a SBC might be considered cookie cutter,but not so much a 327 as a 350,383. And BBC is not an option at all. |
Well kinda splittin hairs now...a SBC is a SBC is a SBC
I think the only time you wouldn't get crap for a SBC being "cookie cutter" is if it was a real 302...and its STILL a SBC Nothing wrong with them I love em and i love my 307 but to say a 327 is "rarer" and only better for that purpose is kinda ridiculous. especially when it(383) would probably work better for you in almost every way in terms of driveability. |
i wouldn't say that a SBC is a SBC, i still am a little shocked when i see a 283,327 and especially a 302. and that is shocked in a good way. i do agree with the idea that the 383 would be a far more fun ride and would do it while being more street friendly in being able to keep lower rpms but still make good power, likely better than you will make out of the 327. but i can understand the thought behind the 327. but i dont think in the OP's case that he should go after too much power if he still want to stay with the 327 in the car he has picked |
GM self aligning rocker arms - $61.95 http://www.summitracing.com/parts/NAL-12495490/ Head bolts - $25.95 http://www.summitracing.com/parts/NAL-12367959/ Vortec Intake bolts - $19.95 http://www.summitracing.com/parts/ARP-134-2002/ Head gaskets - $30-$60 for a pair depending on the set. Vortec Intake gaskets - $21.95 http://www.summitracing.com/parts/FPP-1255/ AND some sort of valve spring upgrade. $60 That puts you at least in the $1026.75 range. Only about $75 savings. Even still, you'll only be able to get .450 lift with only a spring change, a little more with a seal change I've heard, unless you go with beehive springs and matching retainers. That would be another $325 at least. I think it's not that bad of a deal AND you can get up to a .525" lift. |
super beatle if you actually look at the heads i posted they are rated for a lift up to .520" and the scoggin' dicky heads are rated for a lift of .525" i would say the difference is litterly splitting hairs, so you can take that 60.00 off that price that you came up with. then if you look a the scoggin dicky kit it doesn't come with self-aligning rockers either so you take the 61.95 off the price that you came up with too, that will leave you with about 900-940.00 and that from 1109.00 is a solid 150-200 savings and that is worth it so now do you see why i say the price from scoggin dicky is a bit steep, you and i just priced all the parts in their kit from other sources and came up with 900-940 bucks, so why is their's 1109.00
Good call. I looked at the link, but was thinking they're 060 GM heads with the .450 lift limit cause I just glanced at them.The dickey kit does come with "GM stamped rockers" like the ones I posted a link to. Either way, you could save some $$$ buying the parts individually through Summit and spend the savings on other needed parts. That and Summit has great service and cheap, fast shipping. |
| Has anyone attended Sollers Point Technical High School? | mgold | Hotrodders' Lounge | 0 | 08-30-2009 09:45 AM |
| gen V high performance heads | Getlow1500 | Engine | 4 | 04-11-2008 12:08 PM |
| car life after high school | sumdaymyownshop | General Rodding Tech | 4 | 02-06-2005 03:34 PM |
| high performance 283 | steve | Engine | 2 | 06-22-2003 03:25 PM |
| high performance parts for 5hp honda engine? | atlantisjones | Engine | 1 | 05-19-2002 07:44 PM |
