Schulz air invasion? :) - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-23-2012, 02:20 PM
Old Fool's Avatar
Originally Posted by loctite
OLD FOOL!! So you are saying I need to have a 60 amp breaker and #6 wiring? I will have to check to see what my old compressor has. but i know it has a 30 amp breaker that I will have to change out. My compressor is right next to my breaker box so i will only need a few feet of wiring. Thanks for the help.
I just posted what the National Electric code calls for.
Yes the 30 amp wont cut it.
A short story, years ago, 1992 to be exact I had a fire in my garage. It pretty well burnt the garage down. The insurance company had a fire investigator come to determine the cause.
I never heard a final report, but what I do know is the investigator cut the electrical panel loose from all the wires and mast and he took it with him.
Had there been any undersize wire in relation to any breaker it was attached to, I am sure they would not have paid to rebuild and refill the garage.
If you have a short run , a bit of #6 will be cheap, you will have a 50 amp circuit if ever needed, and the starting of your compressor shouldn't experiance much voltage drop.
Better safe than sorry.
That compressor will last you a lifetime, a very nice purchase.
I do suggest you put an auto drain on the tank so that nice new dry clean tank stays that way.
I am to old to remember to drain a tank daily, my auto drain does it for 2 seconds every 10 minutes the compressor runs
  #17 (permalink)
Old 03-23-2012, 10:27 PM
Randy,
Congrats on the compressor! I am glad that it looks like a great compressor. I will wait to hear how it turns out and probably order the same one. It really does look like a nice machine and at 39cfm, it ought to be able to power a decent size sandblast cabinet. Let us know how it turns out.
Geert
  #18 (permalink)
Old 03-24-2012, 01:31 PM
compressor
The compressor came with a auto drain. Heres the deal . I found this compresasor on craigslist just north of me. It was brand new. The man had bought it for his shop but passed away before he could install it. His son wanted it gone. It had the auto drain and magnectic starter box and a gallon of oil with it. all for $1100. So far so good. it runs quiet and pumps up fast.
  #19 (permalink)
Old 12-10-2012, 09:57 AM
Schulz Air Compressor
I wanted to check to see how your air compressor is working out for you?
I'm thinking about the same model and manufacturer. Is it very loud?
  #20 (permalink)
Old 12-10-2012, 10:43 AM
air comp
Its working great!! Not to loud and pumps air up fast!! I use it about everyday as I restore cars. I can use 2 DA sanderas at the same time with no air drop. One da sander used 11.5 cfms My comp is rated at 31 cfms. 7.5 hp 80 gal tank and 2 stage. Hope this helps.
  #21 (permalink)
Old 12-11-2012, 10:57 AM
boatbob2
Wiring..........
The National Electric code,is minimun wiring recomended,i ALWAYS go down to the next LARGER spec wire.Never had a problem........
  #22 (permalink)
Old 09-17-2013, 10:59 AM
Originally Posted by Old Fool View Post
Schulz website states their 7.5 hp motor draws 5.6kw@230v.
That is 24.3 amps.
24.3 amps is 3.5 horsepower.
I think Schulz and Sears have the same advertising director.
Your right till the point I embolden. Schulz's math is correct to state a 7.5 hp Motor consumes5.6 kw of power @ 230v. You are correct in saying that 5.6kw@230v = 24.3VA . I can't figure how you think 23.4VA = 3.5hp. Your math is flawed.
230v * 24.3VA = 5595W 5595W / 746w= 7.5hp their is no direct correlation between Amps and HP. HP and Watts one the other hand are direct relationships because they are both units of consumption
1hp = 746w HP is just a way to reduce the number on power consumption, just as Watts is a reduction on BTU. Sure is easier to say 7.5 horse power then to say 19,090.14 BTU 1w = 3.412 BTU 1Kw= 3,412Btu
The HP they advertise is not a simple as just the 3 numbers your using.
take my Shculz Compressor for example. My motor is rated 10hp with input voltage @ 208 ~ 230v / 460v and 29 ~ 26.8 / 13.4 amps. it has a Eff of 89.5% and a Pf of 78.
with all things being Ideal thats 230 x 26.8 X .78 x 1.732 = 8327w / 746w = 11.16 hp 11.16 X 0.746 / 0.895 = 9.30 HP
11.16 hp + 9.30hp = 20.46 / 2 = 10.23HP is the rated HP
Formulas:
Watts single phase. V x A X pf (power factor) = watts
Watts three phase. V X A X pf X 1.732 = watts
Motor Input HP. W / 746w = Input HP
Motor Output HP. Input hp x 0.746 / Motor Efficiency = Output HP
(this is also called Motor kW and is how things are rated in Europe.)
Motor rating Input hp + Output hp / 2 = rated avgerage.
Oh and since I have a shculz I'll let you know they are a great compressor. Sorry for the derail.
  #23 (permalink)
Old 09-17-2013, 11:32 AM
Faith - Respect - Trust
This is great information and I will file it in my electrical section. Welcome to the forum, when it comes to electrical I have always had a bit of a mind block...when I first got into the mechanical side of the trade, I couldn't screw a marette on 2 wires...now I just can't spell marette so I'm getting better...LOL
Just to let you know, the thread is 1 1/2 years old...just a heads up, I did the same thing when I first joined, but, your information is still appreciated...I take it your an electrician?
Ray
  #24 (permalink)
Old 09-17-2013, 01:03 PM
I'll keep in mind not to necro bump. I'm a Hvac Tech and IT Tech turned into an Energy Manager.
Just had a funny route to get where I am today. I found this site looking for info on my compressor.
I'm looking for a way to filter water out of my Crankcase oil. I'm in a humid climate and have an outside install on my compressor.
Schulz MSV20 Compressor azlo Garage - Tools 2 03-06-2011 07:50 AM
Schulz air compressors rusty 87 Garage - Tools 0 05-27-2010 11:10 PM
The British Invasion 38 special Hotrodders' Lounge 20 02-18-2004 05:46 AM
website invasion lookatme Hotrodders' Lounge 21 02-04-2003 12:12 PM
