scorpion roller rocker ok? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2011, 02:46 AM
001mustang's Avatar
Think these roller rockers are any good?
Rocker Arms, Stud Mount, Full Roller, Aluminum, 1.5 Ratio, Fits 7/16 in. Stud, Ford, 289, 302, 351W, Set 16
Old 02-03-2011, 03:46 AM
Andy79Z28's Avatar
scorpion
They are very good rocker arms. I have been using them for 12 years now in my 79Z28 350 500hp running with nitrous in the 10.7 area. Very solid product! Very good company.
Old 02-03-2011, 04:23 AM
ericnova72's Avatar
More for Less Racer
^^^ Agree, Scorpion is among the best, if not the best stud mounted rockers. Very nice, like jewelry, and American made down in Florida. Gauranteed against breakage for life, good for like .800" lift and 1000lbs spring pressure. Company has very good customer service also.
They also make a very nice roller lifter, and are branching out into other engine parts. Supposed to be a good shaft rocker set up coming from them soon.
Old 02-03-2011, 12:06 PM
001mustang's Avatar
I'll be sure to make purchase before the shaft rocker comes out.
Don't need any more temptations
Old 02-03-2011, 12:54 PM
Sick467's Avatar
Last journal entry: Wheels and Exhaust.
I've got them in my 331 stroked 289 on top of some iron World Products Windsor Juniors. They come highy recomended. The only thing I can say is that my heads came with 3/8" studs that would have been to short anyway (even for 3/8" rockers???), not to mention the scorpions need 7/16" studs. I found some studs at the tune of 100$ for the set. I'm sure it depends on your heads and/or your machine shop's capabilities. I just want you to think far enough ahead so that the 100$ cost does not get you like it did me.
Old 02-03-2011, 01:30 PM
001mustang's Avatar
I have world products windsor sr heads.
need world prod part # 830480 (7/16 stud kit).
could not find on google.
I was hoping these will work?
http://www.summitracing.com/parts/ARP-100-7101/
I bet the windsor heads are tapped out to 3/8"-16??????
http://www.summitracing.com/parts/ARP-135-7102/.
Do you know?
Old 02-03-2011, 02:31 PM
Sick467's Avatar
I can't speak for the Sr heads. Mine are the Jr's. My Jr's had 7/16-14 holes tapped in them for the studs and I used these...
http://www.summitracing.com/parts/ARP-334-7203/
The 1.9 Affective Length studs will bolt up and actually work with my Juniors, BUT the portion of the stud that lies inside the rocker would be all threads - Poor application. The longer (more expensive) studs allow for more of that portion to be shank (no threads), but leaving just a few in there so you don't run out of threads for tightening the poly locks on. I assume ALL roller rockers are designed to ride mostly on the shank of the stud, not entirely on the threads. The threads are always slightly smaller in diameter than the shank. How important is this? - I don't really know, but my gut drives me to do it the way I do it.
Old 02-03-2011, 03:27 PM
my87Z's Avatar
Veteran/Firefighter-Paramedic
i've used them in one of my motors that i built a while ago, i dont think you will find anyone around who will have something negitive to say about scorpion rockers
Old 02-03-2011, 03:29 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Scorpion's Been thinking that's what i am going with on my engine, I have really heard good thing's about them. I was thinking Harlan Sharp or Scorpion's or Comp Gold. I have Harlan Sharp's on my 400 in my T/A i really like them also. JMO
But i like having me some fine jewelry in my engine. That was for you Eric.
Cole
Old 02-06-2011, 06:54 PM
Landshark928's Avatar
FrankenPorsche
I was blown away by how nice they are for the price. You need clear valve covers to show them off.
Old 02-06-2011, 07:34 PM
001mustang's Avatar
i would stick a photo of those on VC...unless...of course...you find a glass one.
Old 02-06-2011, 08:10 PM
FrankenPorsche
Just realized how dirty my plug wires are...
Old 02-06-2011, 08:35 PM
001mustang's Avatar
i did not notice them either.
eyes glued on the eye candy lifters and girdle.
Old 02-06-2011, 08:53 PM
001mustang's Avatar
is there some kinda spec for how smooth valve stem tips have to be before installing new lifters.
Do you have to file/sand/polish valve tip flat or something?
My valves never rotated and there is a very small groove worn in them.
Guess i don't rpm engine enough to float valves.
wouldn't want to wreck new rollers.
maybe change geometry to form new groove in a different location?
Scorpion Roller rockers Cracked!? awoodman Engine 6 08-06-2009 02:25 PM
Scorpion Roller rocker problem SBC maliboo Engine 27 07-08-2009 09:41 PM
Scorpion Roller Rocker Problem 4onthefloor 2 Engine 5 12-07-2004 07:47 PM
Scorpion Roller Rockers 2wld4u Engine 9 09-09-2004 08:44 AM
Scorpion roller rockers 85s-10prostock Engine 0 11-27-2002 01:02 AM
