-   -   Scorpion Roller Rocker Problem (http://www.hotrodders.com/forum/scorpion-roller-rocker-problem-53605.html)
4onthefloor 2 12-07-2004 11:59 AM
IM USING SCORPION ROLLER ROCKER'S PART #IOOI ON MY SBC WITH DART 2 HEAD'S AND STOCK LENGHT PUSH ROD'S MY PROBLEM IS THEIR'S ONLY 4 OR 5 THREADS ABOVE ROCKER'S FOR NUT ANYONE ELSE HAD THIS PROBLEM
DoubleVision 12-07-2004 01:24 PM
NO NEED TO SHOUT LOOSE THE CAPS.
Sounds as if the heads or the block or both have been milled some what, you`ll likely need a pushrod lenth checker and custom lenth pushrods.
camarochas 12-07-2004 01:27 PM
I had the same condition with Edelbrock alluminum heads on my BB Chevy. I had to replace the studs with longer ARP studs.
Rogers Performance 12-07-2004 02:50 PM
The rocker fulcrum need to be on the root of the stud no threads part.
mike
lluciano77 12-07-2004 07:04 PM
I have pretty high pressure valvesprings. I originally had ARP regular length studs. I kept breaking them. I switched to the studs that are designed for roller rockers, and haven't broken one since. They are approximately 1/4" longer. That will give you more thread.
Just make sure your valvetrain geometry is correct. With excessively milled heads, you may need different pushrods.
4onthefloor 2 12-07-2004 07:47 PM
my head's have not been milled and
I'm going with your advice thank you for your input ps Iwill let you know
