Bogie |
Your valvetrain geometry is what dictates push rod length. You need to get a solid lifter and an adjustable push rod. Check to see what length pushrod this combination is calling for. There are too many variables to just assume anything.
As mentioned you also need to check push rod slot clearance and if they need to be opned up, the heads are going to have to come off anyway. Save up a little coin to get screw in studs and be done with it. Down the line you will want more power and a bigger cam, that's just the way it works. The problem could very well be that the rockers are just too thick for the room you have. |
| Roller rocker problem | Curtis Thornton | Engine | 10 | 05-19-2009 12:44 PM |
| What roller rocker arms should I get? | eric32 | Hotrodding Basics | 3 | 04-06-2009 03:57 PM |
| Roller Rocker Swap | MHOWELLRACING | Engine | 4 | 12-21-2008 04:22 AM |
| Roller Rocker Swap | MHOWELLRACING | Engine | 1 | 12-19-2008 05:13 PM |
| lifter cam rocker problem | tomthecomic | Engine | 8 | 10-26-2008 09:38 AM |
