trying to get away with pump gas, as this will be daily driven, not raced. i get mixed opinions in searches. some say quench too high, but if i drop that, then scr and dcr go up. some say i'm ok. just looking for others opinions on this setup. from all i figured, at my elevation, air temp and such, i should be fine.
This head is a version of the small chamber swirl port used on heavy duty trucks.
This is probably on the edge of OK with 91-93 octane unleaded. If necessary detonation can be controlled with less advance, richer mixture, cooler intake and/or operating temp, stiffer gearing, using 1.6 rockers. The latter keeps the valve open higher from the seat in the closing ramp which will bleed off compression faster and more total volume than will a 1.5 rocker.
Less advancce is very effective but usually isn't desireable as power output goes away at a faster rate and in amount when reducing the amount of igniiton advance than it does when reducing compression. Still it's a useful trick especially if you wire in a detonation sensor as the EFI engines use. That can be combined with an igniiton control box to back out some timing when it hears pinging, so it would only function at those times.
Water or water/alcohol injection is another trick that quashes detonation, there are kits on the market for this. With some electronics it can be used with a detonation sensor to switch on the system only when needed rather than manual control.
You can always open the chamber a little by polishing off sharp edges, genrally polishing the as cast surfaces, and/or by putting Singh grooves into the squish/quench pad.
I would not increase the squish/quench clearance to reduce compression by increasing chamber volume, this is like the dog chasing its tail as the clearance opens compression goes down but sensitivity to compression goews up. You end up having to add serious clearance to get the compression down where even with the additional clearance detonation ceases to be a problem, trouble is by that point the power output is long reduced.
So this means your deck clearance is .012 is this correct. With the 8.4 it should run on 91 octane at 36* total timing.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
