scratch : ( - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2011, 06:28 PM
defilade's Avatar
2012
scratch : (
I got a scratch on my El Camino since its a long way from the paint booth can I just sand down the damaged area and hit it with primer as a way to protect the metal till its ready for paint?
Old 10-20-2011, 07:27 PM
dinger's Avatar
No. It will eventually rust through the primer, in your area, probably in a short time. I would feather out the scratch, primer, buy a spray can of the closest color I could find and touch it up. Then fix it properly when you get the chance.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 10-20-2011, 08:45 PM
Art Deco's Avatar
Just one scratch like from a key? Or multiple scratches?
If only one get a hypo needle fromthe drugstore. Put a bit of touch up color in it and drag it through the scratch. Wait 14 days and wet sand it. then wax.
Old 10-22-2011, 02:27 AM
I say if your fixing a scratch for the fort time and your still a bi hesitant about it then go ask a friend whose more expert or has an experience on this to do the touch-up for you, since doing this yourself might just make it worst or you might end up regretting on doing the touch-up yourself. Then of course its best that you bring this to the nearest paint-up service center to get it properly fixed before rusting starts. goodluck with that!
what grit scratch? panelwagon62 Body - Exterior 2 06-09-2010 06:50 PM
Scratch in the new car zipfactor Body - Exterior 1 07-06-2008 07:23 PM
Almost from scratch jeeter33 Engine 1 10-31-2007 07:28 AM
Zoomies from scratch. BigBlockT Engine 2 06-19-2007 07:16 PM
M22 from scratch? 69ChevelleAddict Transmission - Rearend 6 09-15-2005 06:46 PM
