Scratch built Cab on Ford Ranger frame? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2011, 07:33 PM
Wiki Edits: 31
I bought a 1994 Ford Ranger 2.3/5spd truck as a donor for the front suspension. Now that I have gotten alot of the front sheetmetal out of the way, I can see that at least the front section of the frame ( suspension and cab ) will fit my cab, or I can make it fit, and simply back half the frame with the rails I built on the jig, just cut in half more or less.. I was thinking that, I could cut the floor right out of the '94 cab, lift the cab off of the cut floor, cut it to fit my cab and set my cab on it. floor and cab mounts somehow are pretty much mint condition. When I cut the core support off, the core support mounts pretty much fell apart, and the bed was half rotten. Frame is perfect tho..
Any insight? I took the week off work and have off till tuesday.
Old 05-24-2011, 09:08 PM
Wiki Edits: 31
I'm also using the steering column. I have 2 keys, it's solid, locks and the switch is good.
Old 05-24-2011, 09:32 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
if you already have a floor in your new cab, using the ranger floor seems like it would be more work than just making the mounts fit the new one
Old 05-24-2011, 09:44 PM
Wiki Edits: 31
My cab currently has no floor. I have to make the cab fit the 29" wide frame width no matter what I do, but that part will be simple.. I have enough 18ga to build a floor if I need to. I was also thinking for all that the seats in the Ranger are trashed the tracks and the mount point for the seats are right there, so I can make frames to fit my 'bomber' seats and have them adjustable.
Old 05-24-2011, 10:00 PM
& matts38chev
well then, if you dont have a floor, i would have a look at using the ranger floor
Old 05-24-2011, 10:12 PM
Wiki Edits: 31
I only gave $300 for the truck, so any parts I can use from it will put me that much farther ahead. If I didn't want to run a 30" tire in the rear and still have it low, I would use the frame as is, but I don't want to sacrafice the stance, the code 86 7.5" wont hold a 460 and my friend needs the leafs, so if I use the Ranger frame, it's gonna need to be back halved
Old 05-26-2011, 08:54 AM
Wiki Edits: 31
Sure is pretty ugly in the back.. but I measured things up before I bothered to take the cab off.. The orig cab was about 65" from the front cab mount to the rear, and the rear cab mount was placed right on that rear frame 'swoop'.. My cab is 48" long, so I can cut the frame in the lower flat section, and use the rear parts of the rails I built for a back half. This is giving me a mounting place that can accept a 460, transmission crossmember that can be mod'd to work for the C6, and a front suspension that has readily and cheeply available parts for $300 + whatever I get back on scrap and I have a 2.3/ M5OD that is seemingly good altho I can't make it run without a new harness, I can probably make money on this deal selling what I don't need and scrapping what is worthless... I think it'll look and work ok when I'm done. I just want a safe reliable hotrod cheaply.. I know most probably frown upon the mini truck frame on an early car body, but what most don't know is, when I sized the body up, I took measurements on a 1991 Toyota pickup and a 1998 Ford Ranger straight cab pickup, so proportionally, this cab is about right for the Ranger front frame section, even tho it's taken me 3 years to come to this conclusion and it was never intended to be that way
27 ford tudor frame from scratch? joeyb General Rodding Tech 4 02-25-2010 10:18 PM
32 Ford on a s10 or ranger frame david ahluwalia General Rodding Tech 7 07-12-2007 09:48 PM
Who has built their own frame from scratch? Riot Racing General Rodding Tech 14 04-05-2007 08:58 AM
Scratch built IFS? rlackey Suspension - Brakes - Steering 10 04-13-2005 09:57 AM
!986 Ford Ranger Bent Frame SpideyOnTheWall Suspension - Brakes - Steering 2 02-26-2004 07:46 PM
