I find myself a Grant aftermarket wheel as all they are are a simple plate that bolt to a column adapter..use the grant column adapter to fit the column that you are using and then cut a center out of a piece of plate and then weld up a circle out of the chain for the rim of the wheel..the adapters are cheap enough that getting one online and using it as the pattern for the holes needed in the plate is feasable..
http://www.grantproducts.com/t-faq.aspx http://www.grantproducts.com/c-225-s...tion-kits.aspx You can see the bolt pattern used in the pic.. these are chain wheels they make: http://www.grantproducts.com/c-21-chain-wheels.aspx using this info running your self up a custom wheel is a doable thing... Sam
Let's also put this thread in General Rodding Tech.
Dan
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
| Recent General Rodding Tech posts with photos |
| Steering wheel adapter, 9 bolt | jimcar-9 | Suspension - Brakes - Steering | 3 | 08-10-2007 09:21 PM |
| steering wheel security, anyone try one of these? | xxllmm4 | Hotrodders' Lounge | 6 | 02-08-2007 08:04 PM |
| 17 in steering wheel COVER ? | 39chevy | Interior | 2 | 12-30-2006 06:54 PM |
| cleaning a steering wheel | william27103 | Interior | 4 | 12-05-2005 08:35 AM |
| To build own steering wheel or not | neil madsen | Interior | 16 | 03-07-2003 01:30 AM |
